3900 flow
    • 13533
    3900 flow
  • ssdurango
    • Dec 2004
    • 170
    Why are the last 3 cylinder so low?
      1st 3 are intake, last 3 are exhaust side.
        i thought there already was a 3900 flowsheet???
        oh well, more information for DD2003 to play with.
          Well... now i know what's going to replace my 3500 one of these days..
          Just need to get those exhaust numbers up to 200 CFM
          • TiredGXP
            • Jun 2008
            • 107
            These are stock flow numbers?
              Yes
              and the intake flow is like 20 CFM higher than my ported 3500 heads
                Live life 3.7mi at a time
                • 4555
                200cfm at .300" that's insane for stock 2v heads.
                Well, technically you should see 75% of intake flow on the exhaust for naturally aspirated.
                  • 13533
                  Those are stock numbers off my bench. Its 72% avg I/E ratio, but that is .050 to .600. The exhaust should be higher, and that ratio John posted is just a guide. The better the exhaust flows, the longer you can let the power stroke go before opening the exhaust valve.
                    I always heard 80% for N/A.. Either way, those are crazy numbers.
                      • 4555
                      Yes, it's a guide, just like the throat vs. valve area etc. Besides, those numbers will change a lot with manifolds on.
                      • pontiacjeff
                        • Jun 2004
                        • 147
                        holy snit. A 400 Pontiac RAIV or SD455 head doesn't flow like that!
                        Jeff Ianitello
                        Engineered Performance
                        Atlanta, GA.
                          • 13533
                          well, neither do these heads Its really close, but I am going to flow a couple more heads before I post the new numbers. I know better... oh well. I had taped the intake ports but the tape wouldn't stick, even at .050" lift on the valve I was measuring so I thought the ports were sealed that well by the valves. Once I get higher lift, the tape will stay, barely with the suction.
                          This time the same head flowed 195-197 at .300 and mid 250s max. Still impressive, but the high lift doesn't keep on going like it shows on the current sheet.
                            • 4555
                            DOH!
                            I always run tests consecutively with checking in between.
                            Try the silver air conditioning tape, it will hold.
                              • 13533
                              I run consecutive and normally use duck tape, but I have this blue masking tape and its weaksauce.
                              This head reflowed the same today as yesterday so I am going to go grab another stock head to verify it.
