2000 OBDII running 2005 3400 (Fiero Swap)
  • Kaiju Senso
    • Sep 2010
    • 82
    I'm getting closer to my Fiero's engine swap (next week!) but hit a little snag about running this 2005 Equinox 3400 (LNJ) in my '86 Fiero 4spd. I want to run this motor like the previous generation with a 2000 computer and harness from a 3400 car (have yet to find a good donor from pull a part). The crank triggers have me confused because they changed it over in 2005.
    What I want to know is, can I install the External 7x crank trigger from WOT-Tech and not have to worry about it or (as someone from Pennock's suggested) can I swap out the timing cover to a 2000ish motor with the trigger behind the balancer? Any input would be much appreciated.
    • 9189
    You will need to use the external trigger. The trigger on the back side of the crank is not a "keyed" sensor. In other words, it doesn't know where the cylinders are in relation to its triggering, so it will not work for what you are trying to do.
