Difference between 99 3400 and 2000+
  • cooguyfish
    • Jul 2008
    • 31
    I'm looking at buying an alero that is a 99. I know it is not as desirable a motor because the heads are different from what I remember. It needs an engine swap done anyway, so I was thinking about using a 2000+ engine since they are easier to find.
    Will it be a direct swap? If I have to change out sensors and such no big deal but If I'd have to change out wiring or computers that's another story
    • 9190
    There are no differences that I can think of that will require any wiring, let alone PCM changes. The only real differences are the castings of the heads, lower, and upper intake manifolds.
    Droid via Tapatalk
    • cooguyfish
      • Jul 2008
      • 31
      That is exactly what I was under the impression on. Fantastic thanks a lot.
      • bob442
        Show Me Your KITS!
        • Nov 2008
        • 1305
        i believe the EGR is different and the timing chain sucks. lower intake manifold might have a difference hook up for the heater core line, not a big deal, it can be retrofied
        • Jonpro03
          • 362
          Fuel pressure regulator is up to 55psi from 43.5
