Just copying and pasting 3900 info that I am finding while looking for pics. Ill give links too.
Vortec 3900 V-6
According to GM, the new Vortec 3900 V-6 is a close relative of the 3500 V-6 launched in the 2004 Chevrolet Malibu. The 3900 is the first GM overhead-valve (OHV) engine to utilize variable valve timing (VVT) and displacement on demand (DOD).
Engine size was increased 400 cc with DOD in mind. GM engineers felt that the larger displacement was needed to get optimal performance in the three cylinder mode.
To keep from having to cast a new block the larger bores in the 3900 are created by lowering the bore center on the block.
DOD works the same on the 3900 V-6 as it does on the 5300 V-8, though rather than alternating cylinders on each bank, the 3900 drops the left ban when in DOD mode.
The variable valve timing system uses and electronically-controlled, hydraulic gear-driven cam phaser that can alter the relationship of the camshaft from 15 degrees retard to 25 degrees advance (40 degrees overall) relative to the crankshaft.
By using VVT, GM engineers were able to eliminate the EGR valve and also found that maximum exhaust-valve opening helped to warm the exhaust catalyst quicker, improving cold start emissions.
The VVT also works in conjunction with an active manifold GM says that the variable intake manifold serves as a low speed torque enhancer giving the engine a broader torque curve.
A valve in the manifold creates a longer path for intake air at low speeds, enhancing combustion efficiency and torque output. At higher speed the valve opens creating a shorter air path for maximum power production.
The 3900 has GM's latest ECM currently available. The Motorola-based E67 has 32-bit processing power and 32 megabytes of Burst Flash memory, 32 kilobytes of external RAM and 36 kilobytes of internal RAM plus a high speed CAN bus to deliver the necessary power to run VVT and the active manifold.
The 3900 also has electronic throttle control that enhances the engines interface with DOD.
The 3900 will be built at GM's Tonawanda, N.Y., assembly plant.
http://www.findarticles.com/p/articl...3/ai_111617012
Vortec 3900 V-6
