65 MM throttle body
  • jschmieding
    • May 2009
    • 44
    65 MM throttle body
    What should i do for a gasket for the 65 MM throttle body? Use gasket maker or try trimming a gasket to fit?
  • 95SleeperAcheiva
    ArtofOlivia"PocketRocket"
    • Jun 2006
    • 694
    razor and roll of gasket material. worked on mine. about 10 bucks. autozone or anyone carries it, use paper material.
    • 19Cutlass94
      • Apr 2005
      • 770
      I just trimmed a stock 3400 gasket. If you have enough patience itll work.
      3400/Getrag 284 5spd
      350/NV3500 5spd
      2014 Chevrolet Malibu LS
        • 13531
        Stock gasket modified is how I do it.
        • jschmieding
          • May 2009
          • 44
          Thanks guys for everything. I have one more question. I am doing a 3500 top swap on my 3400 and am having a little trouble trying to figure out how to use the valley gasket from the 3500. Do I just trim to fit? Its the gasket that goes between each head in the front and back.
            Live life 3.7mi at a time
            • 4555
            You can cut the little tabs off the orange ones and use sealer on either side, but it's just as easy to handle it like you would the 3400 and use straight sealer.
