timing chain
  • rayruner
    • Apr 2010
    • 40
    timing chain
    Just removed the timing cover on my 02 3100, chain is stretched pretty bad, I just installed new chain and factory gears about 8 months ago, not to many miles. the area inside the cover was pretty dry , not much oil, does anyone know how the chain is oiled on a 3100 . I was thinking of drilling a small hole in each plug in the lifter gallery behind the cam gear like the big block, anybody try that, and if so what was the result. thanks
    • 13533
    The oil that gets squished out the side of the last cam bearing is slung onto the chain by the cam gear. More oil might help, but the 2000+ chain is just tiny compared to the older stuff.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Ray,
      Your chain stretch issue is no big surprise. Your next chain might benefit from sending it out to WOT-Tech.com for some treatment.
      • rayruner
        • Apr 2010
        • 40
        chain stretch
        Ray,
        Thank for the replys, I think I'm going to drill a small hole , about 0.30 in each one of the plugs in the lifter gallery or the pulg under the cam,. I done that to my big block which solved the problem on that engine. I got a email into ben, I'm going to wait and see what he saids first.
        • rayruner
          • Apr 2010
          • 40
          My 98 s-10 2.2 has a hole in the plug under the cam to oil the chain, starting in 98 the hole is bigger than in the earlier trucks.
            • 13533
            I wasn't planning on copy/pasting my reply here to your email:P
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              That's left for the gov't to do. lol
