I can get you a photo of an LS-V8 cam gear with the variable pulse width cam signal today-it's Long, Long, short, shortest, IIRC. Have to set cam timing on this one, as it's got a bad habit of jumping time.
Do you want to do a 3900 swap? whats stopping you
that will give some idea of what to expect on the 60V6 at least. I get the feeling that the notch/tooth end points will all line up with each other in terms of crank phasing. that should produce a cam signal where the ratio of time between a leading edge and falling edge can be decoded using the TIC channel's ability to generate interrupts on level changes rather than just falling edges as it is done currently.
I've had the desire to put a turbo on the LZ9 in my '08 Uplander Cargo van but I don't think the chassis and ride height would handle it well.
But considering the 4500lb weight of the van, the VVT 3.9 gets it around pretty well and I can't help but want to add some headers and a VVT cam if I could find someone to produce either lol. Aside from the Overkill PCM/TCM tune I have, I'd love another 20-30hp...
