DOHC VS Pushrod weight
  • donk_316
    • Mar 2004
    • 427
    Settle this dispute!
    Im near positive the dohc weighs in at around 80 pounds more than a PR...
    Can someone back me up?
    1984 Indy Fiero 3.4L
    13.7 sec @ 98 mph
    *ALL THROTTLE AND NO BOTTLE*
  • TheProfessor
    • 869
    my buddy says probably 100 pounds or more
    and that the block alone is heavier
    I Like V660s
    Does Chevy make beer
    ~Jayme~
      • 13533
      The block is 6 pounds heavier. Cams add 17 pounds each I think. Its definetly heavier, but I dunno about 100 pounds. The crank and rods and all that crap are the same, and the intake manifolds are pretty close.
      • robby1870
        Squaddoosh
        • 584
        pushrod heads are around 22lbs each (might be 18, but Im 100% its 2lbs from 20), not sure about DOHC heads.
        Robby Whitesell
        2006 Pontiac G6 GT
        1985 Toyota Pickup DLX
          • 13533
          I dont have a scale anymore, but I pick them up all the time. With the valvetrain bolted on, the DOHC heads are probably 10 pounds heavier. The stock lifters are also um...77 grams * 24. You also have the timing belt stuff, the cam gears, and the timing chain cover differences. I guess we need a heavy duty fish scale (not gonna be a fish scale, thats the only term I can think of) and a hoist.
          • RacerX11
            • 1060
            Are we talking iron or aluminum pushrod heads?
            Marty
            '99 Z-28 - Weekend Driver
            '84 X-11 - Time and Money Pit
            Quote of the week:
            Originally posted by Aaron
              • 13533
              I am talking aluminum, since its the FWD platform and thats all the DOHC came as.
              • Anonymous
                Although i don't haev exact weight, I know that the DOHC heads are heavier(than a set of 3400 heads that I had). And that was without the cam carriers. Those cam carriers weigh a lot too!
                  • 13533
                  The cam carriers are aluminum and dont weigh hardly anything.
                  • gpse3400
                    • 1460
                    When I pulled the TDC in favor of the 3400 the nose of my car rose 3/4"-1" and the tracking became more precise, doesn't feel like its dragging its ass around the corners as much as it used to...... So, work on that one....
                    Lorenzo
                    • Anonymous
                      I meant with the cams in them
                      • geoffinbc
                        Iron Head Enthusiast
                        • 5831
                        You never mentioned one word about the cam.
                        • 3100 MPFI
                          • 1522
                          Using the 1995 Chevy Monte Carlo as my baseline.
                          3100 AVERAGE base curb weight = 3276 lbs.
                          3.4 DOHC LS Z34 BCW = 3452 lbs.
                          A differance of 176 lbs.
                          Now, I know that there can be some weight added with options.....
                          BWAHAHAHAHAHAHAHAHAHA
                          A 1995 Monte Carlo with OPTIONS?????
                          The car gets a plastic armrest. I rest my case. :wtf:
                          Taylor
                          1998 Lincoln Mark VIII
                          • Anonymous
                            Its fricking common sense, the cam carriers themselves weigh like nothing, so becuz I said "they weigh a lot!", I figured you'd get the hint.
                            • Rhedalert
                              Dr. Feelgood
                              • 1574
                              So if you wanted to keep apples vs apples, basically you'd have to race the Z34 without a DRIVER?
                              Brian
                              3400 SFI V6, 4T60e
