Billet TB Linkage Install
  • redline1000x
    • Dec 2008
    • 2
    hrmm, very interesting, and looks like a very easy job, what im wondering most about this job though is this.... would this tb fit on my 3.1 rear wheel drive engine? my intake plenum isnt the same as the transverse engine intake plenums. if so consider 1 sold!!
      • 13520
      They only bolt up upside down. The TB was designed to turn the shaft the other way but I don't know that it would work on an iron head manifold.
      • Jibbs.
        • Apr 2009
        • 4
        any suggestions about what to do when you MAF is smaller then the giant T.B.
          • 13520
          Buy a larger MAF.
          • Pillsbry10
            • Jul 2010
            • 6
            so it wont work on a 3.1 camaro motor...but what about the 3.4 motor the tbs bolt on complely diffrent
              • 13520
              #21
              You can possibly make it work, but it wasn't designed for that application.
              • carbon
                Procrastinator
                • 388
                #22
                Is this retainer ring on the TPS side needed or should it be left out? There is no reference to it in your walkthrough...
                Also... is it possible to reverse the rotation on this throttle body? The stock Fiero cable setup is to pull from the plenum side. I see the second hole for the stop screw, but that would screw up the TPS or could that just be 180'd as well?
                - Ben
                • CNCguy
                  Bisong eater :P
                  • 1017
                  #23
                  The second hole is exactly for that purpose. The TPS can be rotated 180 by grinding off the locating tang. Another option is to use the throttle shaft from a mid '90s 3100 with the metal bellcrank. The bellcrank can be pulled off by grinding the end of the shaft off, rotating it 180 and welding it back on. This keeps the TPS and throttle stop in the original positions. You can also move the bellcrank closer to the TB by removing a spacer on the shaft.
                  MinusOne - 3100 - 4T60E
                  '79 MGB - LZ9 - T5
                  http://www.tcemotorsports.com
                  • neophile_17
                    • Jun 2004
                    • 306
                    #24
                    It's also almost trivial to flip the throttle cable around so that it pulls the other direction. What bracket are you using to hold the stationary part of the cable?
                    ~sam
                    • carbon
                      Procrastinator
                      • 388
                      #25
                      ~sam
                      I know... I just like how it runs behind the plenum mostly out of sight. I haven't come up with a bracket yet, but if it looks like the 3400 will work the best I may just go that route.
                      Any comment on the retaining ring in my first pic? It's the reason you need a hammer to remove the shaft from the original TB...
                      - Ben
                      • alpinestar10
                        • Apr 2010
                        • 194
                        #26
                        Its up to you if you want to use it or not when i tore apart my old tce unit the previous owner did not include that and it worked great
                        • CNCguy
                          Bisong eater :P
                          • 1017
                          #27
                          ~sam
                          It's pretty easy to make something like this.
                          '79 MGB - LZ9 - T5
                          • carbon
                            Procrastinator
                            • 388
                            #28
                            I never really thought to go inside next to the fuel rail... nice!
                            - Ben
