homemade motor mounts
  • FastGT31
    • Jan 2004
    • 146
    i cant rememeber if it was this site or another but i searched here and couldnt find where to get polyurethane. has anyone here ever bought it and where did you get it from? and if so, how did it work?
    • 13530
    You can get it in a tube from any hardware store. I haven't used it for bushings but I have used it and its real easy to work with and its definetly stiff once its cured.
    • tractorman
      • 451
      I've used "urethane" glue to glue vehicle windows in place- it comes in a tube like caulk. They'll try to sell you "butyl", which won't work- that shit is just for windshields... it doesn't harden. Urethane sets up real good.
      • FastGT31
        • Jan 2004
        • 146
        found it!
        McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
        poly resin 8644k11, and many others to chose from
        • tractorman
          • 451
          What's wrong with the stock setup? It's not like these V6's are motormount-eatin' torquemonster bigblocks.
          I've never understood all the hype about polyurethane bushings anyway. When the radius arm bushings on my old ford truck went bad, I replaced them with polyurethan bushings. Since then they've squeaked and clunked when it's cold out.
          • sharkey
            • Jun 2004
            • 2061
            with a j-body, the mounts suck. they were originaly designed to be used with the low power 1.8l ohv that made 85hp. when the motors got morw powerfull (1.8 &2.0l turbo) and heavy (v6) the mounts never got upgraded.
            my car is very clunky (mounts are to soft to keep the motor mounts from bottoming out in itself) and very anoying. with urethane mounts, its a lot stiffer.
            im currectly designing my own mounts. stay tuned.
            • tractorman
              • 451
              good to know- is a corsica/beretta a J-body, then?
              I can't say I'm too impressed with my '94 corsica's motor mount setupl. I upgraded to the improved '96 design for the top mount, and it's been ok... but the bottom link is a bit loose.
              • El_Diablo
                STFUniversity
                • 917
                n-bodies are also known for engine movement, when i rev my engine in park it will move the engine a quarter to half inch or more
                if you go Here! you can find an engine brace to help with the problem, its still in development but it should be out in a little while
                • Guest
                  Wow, that looks so ghetto.
                  But now I have another forum to peruse.
                  • tractorman
                    • 451
                    Heh... that looks like something I'd weld onto a tractor...
                    That link looks solid- that's gonna shake like a lawnmower.
                    But it's not a bad concept. If my corsica's mounts give me any more trouble, I could adapt a link or two off a Lumina type setup and hook it to the radiator support.
                    • El_Diablo
                      STFUniversity
                      • 917
                      well the heim joints still allow movement but they cut down a good bit and remember- this is the prototype, things will be different on the finale version
                      he also has intakes that are alot like some of the others on the market, as well as strut bars
                        tractorman: My stock v6 3100 has ripped the upper mount in half. Lower dog bone is trashed, and I'm sure my trans mount isn't in good shape either. I upgraded my uppermount to the 95+ style too, that helped a lot, but now it's about done too. Thinking once it goes, I'm going to get the advance auto parts solid rubber mount, and then get the rksport poly upper insert. If you add dogbone mounts to the radiator support, keep your other stock mounts. The L body radiator support is not a strong struture and will bend/move with the motor.
                        I've got poly on my swaybar and it doesn't squeak. I've never had poly squeak, but maybe I'm lucky?
                        • El_Diablo
                          STFUniversity
                          • 917
                          if you keep poly greased it wont squeak but it can start to squeak as time goes on or if its not properly greased.....
                          • tractorman
                            • 451
                            You're supposed to grease polyurethane??
                            Hmmm... that never occurred to me. I suppose I could spray it with some WD40- I'm sure that'd take care of the squeak. Probably not the clunk though- that $hit shrinks when it gets cold.
                            • Syn
                              The Master Piece
                              • Oct 2005
                              • 599
                              i made a few of my mounts solid, easy to do too
