Need part number for item
  • kverskvfd
    • 17
    Does anybody know the part number for this item.
    Thanks!
    Charlie
    • 13513
    I have to get some tomorrow as well. They are over $2 each if you go by the ac delco number. I think napa was $1 each or something like that for them. I will let you know tomorrow.
    rockauto.com head dowel pin search will give you the ac delco number.
    • kverskvfd
      • 17
      thanks, the machine shop removed them when i had the block bored and honed and when i put the engine back together it poured coolant into the engine.
        • 13513
        It poured coolant into the crankcase or cylinders? I didn't know it could get that far out of alignment without them.
        • kverskvfd
          • 17
          both, yeah it was like 2mm out of alignment because of the clearance for the bolts to go thru the gasket and then compress.
            • 13513
            FEL-PRO Part # ES74013
            Napa doesn't carry them anymore, and their books dont list anything but iron head engines.
            • OldSkoolGP
              That guy over there
              • 930
              It could have kept the gasket from lining up square. The bolt holes in the gasket would allow for a decent amount of movement.
              • CNCguy
                Bisong eater :P
                • 1017
                I bet the LIM gasket doesn't seal very well with the heads out of position.
                MinusOne - 3100 - 4T60E
                '79 MGB - LZ9 - T5
                http://www.tcemotorsports.com
