LIM torque confusion
  • roxtro
    • Apr 2007
    • 7
    Ive got a 2000 malibu LS 3.1 alum. head, IM using new style FELPRO gaskets
    Ive found 3 DIFFERENT torque specs
    #1. 115in lb all 8 bolts
    #2 9ft lb 4 inside bolts and 18ft lb 4 outer
    #3 18ft inner and 24ft lb outer
    ???????????? THANKS in advance for some help
  • scoopy03
    • Jun 2007
    • 53
    http://cgi.ebay.com/ebaymotors/GM-3-...spagenameZWDVW
    here is what is says on an ebay listing. listing will also show you which one of the bolts need what torque spec.
    here's what is says though
    Tighten the vertical lower intake manifold bolts (1) to 7N·m (62 lb in).
    Tighten the diagonal lower intake manifold bolts (2) to 7N·m (62 lb in).
    Tighten the vertical lower intake manifold bolts (1) to 13N·m (115 lb in).
    Tighten the diagonal lower intake manifold bolts (2) to 25N·m (18 lb ft).
    Planning on doing 3800 Supercharged swap soon in either my 4cyl or 6cyl.
      • 13534
      I dont have the sheet but if someone can scan it before I get to one, please do so. Then it can go in the wiki
        • 9191
        http://60degreev6.com/Articles/Pushr...SB14-3x00.html
        • scoopy03
          • Jun 2007
          • 53
          the listing they did on ebay was just confirmed by that article
            • 13534
            http://www.60degreev6.com/wiki/index...ning_Procedure
            • tractorman
              • 451
              roxtro- where are you getting all these different specs? That gasket set should have a paper included- use the specs that come with the set. When I did the LIM job on my '01 Lumina, the specs in that new-style Felpro set were the same as Scoopy just listed a couple posts back. It's worked fine for a year and a half so far.
