I need to DROP OIL PAN! 3.1
  • 3XTurboAgain
    • Jun 2007
    • 222
    Has anyone ever dropped an oil pan on a W-body with a 3.1? Can i lift the motor from the top with an engine lift and unbolt the lower motor mount and horseshoe? Remove starter, ICM and oil filter adapter and it should come out right? No fun but i have to do it somehow, any tips are welcome! Thanks !
  • sil
    4T60-E killa
    • Nov 2004
    • 723
    might be easier to get those motor holde rbars that go above the motor and hold it there... then undo the subframe ?
    • Runner28
      • Aug 2007
      • 8
      What's it on? You can do it on my daughters Grand Am but, not on my son's Grand Prix. Don't forget about the 6 bolts on the side of it.
      • 3XTurboAgain
        • Jun 2007
        • 222
        Its on a 90 turbo grand prix. Once that lower motor mount comes apart, i dont see why it shouldnt come down, I was wondering what experience you guys have had. What bolts? the oil pan bolts obviously?
        • 1988GTU
          LB62LHObbqftmfw
          • Nov 2005
          • 2475
          The 3.1MPFI pan should just slide right out once that lower motor mount comes out. Good thing you dont have the 3100SFI engine.
          • 3XTurboAgain
            • Jun 2007
            • 222
            Yea im glad its "do-able". Its gonna be some work but its gotta be done. Need that stuff to stay in the motor!! ya know?
            • PCGUY112887
              • Feb 2006
              • 1067
              Why you dropping the pan?
              SpudFiles
              Theopia
              Enjoy life online.
              • 3XTurboAgain
                • Jun 2007
                • 222
                Leaks oil pretty bad in the back corner, leaking all over the trans. Are you supposed to use silicone on the oil pan gasket? I had the motor out but apparently i did something wrong, whats new.
                • 1988GTU
                  LB62LHObbqftmfw
                  • Nov 2005
                  • 2475
                  You made sure the oil leak was not this:
                  • 3XTurboAgain
                    • Jun 2007
                    • 222
                    Yep im sure, i wish it was, i didnt use silicone on my 350 pan and it doesnt leak, i guess v6s need silicone on the pan?
                    • 1988GTU
                      LB62LHObbqftmfw
                      • Nov 2005
                      • 2475
                      Yes you should use silicone on the edges of the pan gasket. You should be able to see were it is needed.
