i just did the lower intake gaskets but when i started the car i was getting p0300 random cylinder misfire....it is a 3.1L..i did install all the pushrods in there original location..i torque the rocker arm bolts to 124 inch pounds then 30 degrees..spec from alldata..i did some searching and saw on another thread that its 89 inch pounds then 30 degrees..does anyone know which torque spec is right..any info will help..thanks
96 monte carlo rocker arm ?
Tags: None
Where did you see 124? Its supposed to be 89. So long as the pushrods are where they belong and the rocker arm isn't loose, your problem shouldn't be with either.Ben
i saw 124 in alldata...i was thinking that the rocker bolts were to tight allowing the intake or exhaust valves to not completely close...i did not have any misfires before i did the job...i also have spark at all the plugs and correct fuel pressure
Anything is possible but I have my doubts that you could tighten them down and cause your problem. They aren't adjustable so unless you crushed the pedastals into the aluminum head, I doubt its keeping the valve open.Ben
Agreed. I would double check your pushrod orientation.Originally posted by SappySE107 View PostAnything is possible but I have my doubts that you could tighten them down and cause your problem. They aren't adjustable so unless you crushed the pedastals into the aluminum head, I doubt its keeping the valve open.
you guys were right retorque the rockers to 89in/lb then 30*...im still getting a p0300 random misfire and a p1406 aux emission controls...im lost not sure what to do next...its rough at idle and start to smell like fuel so im thinking ignition related...need help any input.....
Maybe a stupid question but are you sure you put the coil packs back correctly, and the wires in the right spots? I get my ass confused everytime and have to remember which cylinder is which. It really gets messy when 1 of your coilpacks has no numbers on it.SpudFiles
Theopia
Enjoy life online.
i never took the coil packs off the ign module and olny disconnected #2,4,6 cylinders from the front...i took off the fuel rail again and put it back on to make sure the injectors were seated properly...ive been looking under the hood for hours trying to see if i left something unplugged..cant find anything got all 3 harness hooked up to the ign module...i did NOT have this problem before i did the intake gaskets so it has to be something i did...
