Junkyard engine advice
  • ollopa
    • Aug 2007
    • 22
    I want to replace the blown engine in my daily driver but the car itself is not worth the price of an engine rebuild. I'll be getting a running junkyard engine with a 90 day warranty. I don't want to spend much money but I also don't want to waste a good opportunity while I have the engine on the engine stand. Should I just slap the new engine in as-is or would it be well worth the effort to visually inspect/plastigage/replace the rod and main bearings?
    I have to remove the oil pan anyway (2.8L to 3.4L conversion) and I'm already planning to replace the oil pump.
    Thanks in advance,
    Ollopa
    • 9191
    What car/engine combo are we dealing with?
    • ollopa
      • Aug 2007
      • 22
      OK the car is a '90 Trooper and I'm going to replace the blown (as in dead, not forced induction) 2.8L with a '94 or '95 3.4L from a v6 Camaro.
      • 3100 MPFI
        • 1522
        I always check things out. I bought a replacment 3.4 DOHC for my 1995 Cutlass Supreme that was suppose to be running, but when I was working on it, I noticed something wrong. Turns out it has a broken valve that punched holes in one of the pistons.
        Taylor
        1998 Lincoln Mark VIII
        • ollopa
          • Aug 2007
          • 22
          Correct me if I'm wrong, but it seems like if I'm gonna check the bearings that I might as well just replace them. And if I'm going to replace them, then I should have the crank polished. I'm worried about one thing leading to another and the whole cost of the swap increasing. Are the main and rod bolts reusable after I inspect the bearings?
            • 13533
            You could but check ebay for bearings. They are cheaper there if you can use the stock size bearings. 95 junkyard motor isn't something I would trust without inspection.
            • sil
              4T60-E killa
              • Nov 2004
              • 723
              if it were me, id plastiguge, if ok
              visual inspecition of cyl/pistion via spark plug hole and an LED light on a wire int here.
              compression check
              have someone turn key while checking compression
              or get a starter bumper thing (so you can check yourself) the valvetrain
