My 3100 Leaks a Quart of Oil Every Month
  • gpchris
    • Feb 2007
    • 477
    gpchris.. are you in lowell, indiana??
    no. Why?
    Why is this in the pushrod section?
    Because my 3.1 is leaking oil
    So can I change it without pulling the intakes?
    • 94GPGTP
      95 Grand Prix GTP
      • Apr 2007
      • 593
      I Thought u were.. I was putting some info together.. I guess i was wrong..
      My Mistake!! Sorry
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      Drilled/Slotted Rotors
      White
      3" Magnaflow Catback
      90 Pontiac Turbo Grand Prix
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      230,000 mile Getrag 282
      Emissions Deleted
      Brand new Engine 1,000 Miles
      Fully Custom Built car
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        Originally posted by gpchris View Post
        no. Why?
        Do'h!
        Now's a good time to replace the uimg while you're in there replacing the O-ring. It's not that hard to do, should take you an hour if you're good with the hand tools.
        • 19Cutlass94
          • Apr 2005
          • 770
          I was going to say at the least I believe you have to pull the UIM.
          3400/Getrag 284 5spd
          350/NV3500 5spd
          2014 Chevrolet Malibu LS
          • gpchris
            • Feb 2007
            • 477
            My Mistake!! Sorry
            And can I reuse my year old UIM gasket?
            • 1988GTU
              LB62LHObbqftmfw
              • Nov 2005
              • 2475
              #21
              You can reuse the uimg, but they are so cheap, why not just buy new ones?
              • IsaacHayes
                Mr. Orange.
                • Apr 2006
                • 6030
                #22
                It's more fun to live dangerously.
                • gpchris
                  • Feb 2007
                  • 477
                  #23
                  I replaced the distrubutor oring. To do so i had to remove the fuel rail. Now Im leaking gas. In short trips i can open the hood and see puddles of gas on the LIM by the injectors. I took it all apart again and replaced the lower injector orings and still leaking... Now what? I dont understand how its leaking fuel. The rail is tight..
                    Could be upper injector o-rings.
                    • gpchris
                      • Feb 2007
                      • 477
                      #25
                      But they're cliped on.. How could I have done anything to them. Is it possible that its a cracked injector?
                      • 1meanz
                        • Nov 2007
                        • 197
                        #26
                        mine done the same thing, even tho there clip on, its possible that its the upper o ring. when i first got my hybrid running i had to change EVERY upper o-ring before it would stop leaking. and also, make sure they have a bit of oil on them. and seated properly
                        • IsaacHayes
                          Mr. Orange.
                          • Apr 2006
                          • 6030
                          #27
                          Even clipped they can be moved and if they are moved a little bit (taking the rail off the LIM) then you now have the o-ring at a different angle and the depression from being at a certain angle now is moved, so it can leak.
                          • gpchris
                            • Feb 2007
                            • 477
                            #28
                            It was the oring that on the tube that connect each end of the fuel rails.
                            • gpchris
                              • Feb 2007
                              • 477
                              #29
                              Ok got that fixed now It takes a couple extra seconds to start and the check engine light comes on when it gets to operating temp.. any ideas guys?
                                • 9189
                                #30
                                Have you checked to see what code is set? You may have pinched a wire or something during the work.
