What happens when ?
  • Urbman
    urbs
    • Jan 2009
    • 7
    Question : What happens when ?
    Hello All
    I am a new member. Thanks to all who have put so many good things together on this site.
    Could I trouble you for a pointer or two regarding a flow chart as to what happens during a normal start to a normal warm up.
    I am trouble shooting a 1998 LA1 powertrain. My trouble is that the engine
    seems to run well up to or around warmup and then disintegrates into
    a wheezing mass that will backfire wickedly at anything over aproximately
    1200 rpm.
    So far...
    1. New fuel pump and filter
    2. New fuel pressure regulator
    measures 42 PSi key on engine off, idles around 36psi
    snap open the throttle, 42 psi maybe a bit more.
    3. New plugs, new wires
    4. Static check of coils yields .4 ohm primaries 5.6K secondaries +/-5%
    5. New catalytic converter
    The behaviour is pretty consistent 5-10 minutes of bliss
    (quick start, smooth idle, smart acceleration ) followed
    by a stumble and then limp home at 1000rpm any more throttle and
    a substantial backfire occurs. If I persist ... a stall and a restart
    is required.
    I will try an ICM tomorrow but would welcome any other suggestions.
    It occurs to me that I don't really know whats going on as the engine warms up. Things like ...
    When is the purge valve opened ?
    When is the egr used in this cycle ?
    I looked around the site but I seem to have missed it
    Al
  • carbon
    Procrastinator
    • 388
    Check engine light? Codes?
    Is the O2 sensor in good shape? The engine falls apart when it should be going into closed loop...
    It tries to idle down but the IAC passage maybe plugged choking it?
    Just some thoughts...
    - Ben
      • 9187
      Since you mentioned its good until it gets to normal operating temp, I would definitely check the O2 sensor.
      • Urbman
        urbs
        • Jan 2009
        • 7
        Hello Carbon
        The 02 sensors are new. Replaced as part of this exercise.
        Trouble codes are not set unless I force the throttle and get a sufficient backfire.
        With respect to "Closed loop" ...
        I thought that closed loop was a steady state condition. Throttle position constant,
        engine load constant. I was under the impression that under acceleration this motor
        is not in closed loop.
        Could I trouble you to confirm. I am heading out and will look into the IAC before I start
        on the ICM swap.
        Thanks for the reply
        Al
          • 9187
          Closed loop is when the O2 sensors are controlling the fueling. When in open loop, fueling is done by default table values. Once the engine is up to temp, the O2 sensors beginning monitoring and adjusting the fueling tables as required to maintain a stoich condition.
          • Urbman
            urbs
            • Jan 2009
            • 7
            Hello Bszopi
            Thanks for the information. So I am clear on this ... Once I am at operating temperature
            the 02 sensors are quick enough to be part of the fuel injector duration calculation
            under acceleration.
            Would it be likely that an old and new o2 sensor would behave the same way.
            My symptoms haven't changed since they were changed out.
            Thanks for the clarification.
            Al
            • Urbman
              urbs
              • Jan 2009
              • 7
              Minor update...
              When I went to replace the ICM I noticed that the cable to the crank position sensor
              was wedged against the pipe to the EGR valve. Closer inspection showed that the
              one of the wires is damaged (melted insulation). The cable runs around the back
              of the engine and terminates at a connector mounted on the block.
              The connector from the crank position sensor plugs in here.
              I tried my local napa place but they only sold connectors with pigtails.
              The wire color was also a bit off (not yellow and purple).
              How do you disassemble these connectors ?
              Where can you get pins for these connectors ?
              Thanks
              Al
                I'd go to a salvage yard and yank a whole CPS harness off another 3100 or 3400 car. Should be very cheap. Repairing that harness is not advised since any difference in the wire can cause a change in recieved pulses to the ICM and delivered spark advance.
                I learned that the hard way.
                  yes there has to be so many twists per length of the wire or it can pick up interference.
                  • sprucegagt
                    Old School KI
                    • May 2005
                    • 703
                    Originally posted by Urbman View Post
                    Hello Bszopi
                    under acceleration.
                    Al
                    Actually closed loop occurs when the O2 sensors are warmed up. It's not dependant on coolant temp. Heated O2 sensors (3/4 wire) usually warmup somewhere between 30 seconds to 2 minutes after start up. All depends on outside temp (colder = longer).
                    Your local OBDII moderator
                    2000 Grand Am GT w/ WOT parts
                    • Urbman
                      urbs
                      • Jan 2009
                      • 7
                      Another update ...
                      Just got back from the parts store. To my disappointment the leaky hose is too expensive
                      for me. The hose connects a pipe from the block to a tee fitting and what I imagine are
                      the heater hoses.
                      I am going to try and replace the o rings in the fitting. Are there just two ?
                      (I am having trouble seeing into the fitting)
                      Al
                      • Urbman
                        urbs
                        • Jan 2009
                        • 7
                        Update
                        Hose
                        The connector yielded 2 orings. I didn't know what size the originals were. I replaced
                        the originals with a pair of 3/32 orings.
                        Cable
                        I obtained a new cable (7x crank position sensor to ICM, 80bucks ).
                        I replaced the cable.
                        I would have gone ahead with this but I was still troubled by the symptom
                        that it goes to hell in a hat basket after warmup . I replaced the ICM
                        at the same time. ( The NAPA folks indicated that I couldn't return the
                        ICM, only exchange it so what the heck )
                        All seems reasonably well at this point except that my OBDII scan tool
                        indicates that some "I/M Readiness Monitors" vaven't been performed.
                        The "monitors" in question are ...
                        1. The catalyst monitor
                        2. The heated oxygen sensor monitor
                        3. The evaporative systems monitor
                        Do I have to do something specific to restart these monitors ?
                        (1998 pontiac transport 3400 SFI)
                          • 9187
                          See if that helps (post #4 seems to explain a lot). Might also try disconnecting the battery overnight and see if that does anything for you. Glad to hear it seems to be heading in the right direction, though!
                            Not sure about OBD2 but in OBD1 $A1 code, Closed loop is on 3 seperate timers (cold, warm, hot) and min/max coolant temps for each. After a certain amount of time the ECM assumes the O2's signal is useable.
                            • sprucegagt
                              Old School KI
                              • May 2005
                              • 703
                              I guess it's different with OBDII.
