need part interchange help fast!!!
  • andrew_smith
    • May 2009
    • 12
    i have a 2001 3400 that needs heads. found a set of 01 3100 heads, will they interchange? help fast please i have to let them know if i want the heads or not
    Live life 3.7mi at a time
    • 4555
    Yup, the heads are the same.
    • andrew_smith
      • May 2009
      • 12
      k i wanted to make sure because i went to autozone website and checked the part numbers on the head gasket set and they came up diff numbers. my 3400 is in a venture and i think the 3100 was in a malibu. not sure on that one though
        • 4555
        Correct. The head gaskets for a 3100 has a slightly smaller bore diameter. Make sure you use the gaskets that match your block (3400).
        • andrew_smith
          • May 2009
          • 12
          wow so that was such a dumb ? for me to ask, i shoulda thought about that lol. thanks for the help man. i just wasnt using my head. ive been fighting this stupid van for almost 3 months. started with warped heads, had them milled and the moron took too much off now i need to replace the heads because my valves will not stay closed.
          so the head gasket is the only differance? thanks again man i really appreciate it
            • 13531
            If coolant got in the oil, your lifters are probably need to be torn down and cleaned up. Otherwise they have tendency to act like a solid lifter and the valves won't close.
            You can take over .020" off the heads, and most shops won't do that unless you ask and I have never seen a head warp that much.
            • DEI37
              • Jan 2004
              • 516
              Or, use a shorter pushrod.
              • andrew_smith
                • May 2009
                • 12
                where would i find a shorter pushrod? as for coolant in my oil, i never saw any signs of that. it all went into the exhaust.
                  • 4555
                  Not with stock heads. If there was enough shaved off the heads to warrant shorter pushrods then fine, which may be the case here, but I have to agree with Ben that there is a possability the lifters are retaining water like a woman does that time of month
                  • andrew_smith
                    • May 2009
                    • 12
                    well, im almost positive there was no water in the oil but for safety sakes, how do you take the lifters apart and clean them?
