need help on check light 3.1 monte carlo
  • a19bk66
    • Mar 2009
    • 2
    Question : need help on check light 3.1 monte carlo
    replaced the 24X and 7X sencors and harmonic balancer still getting the 0336 code .I have done the drive cycle at least a dozen times but it still comes back.It shows in the repair manual that the rd/wht wire is the 12 volt sorce and the bl is the grnd and the Lt blue/black to be the sencor return,,in the wiring diagram it shows the opposite red/wt to be the sencor return Lt blu/blk to be the volt sorce,,,any way i go about it the Lt blu/blk has no power but the car is running fine same way on the cam sencor i neeed to get the light off to pass a state inspection,could the pcm be bad and still let the car run,,im at a end of what i have been told to do to it checked every thing grounds to fuses every thing is ok.
    Any thing any idea would be great i'll try it to see if it works
