CODE 42
  • torq455
    If I only had money!!!
    • 1615
    CODE 42
    Has anyone here had the pleasure of dealing with the dreaded code 42...an intermittent one too? I've researched, but I'd like to get more info from someone who's dealt with this.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
  • 60dgrzbelow0
    "Yes... I AM IRONMAN..."
    • Mar 2009
    • 1344
    Find information, resources and relevant links for extreme-check-engine-light-codes.com. This domain may be for sale.
    • torq455
      • 1615
      thanks, but, like i said, i've already researched, and found all of those articles already.
      Andy
        i've never dealt with it personally, but replacing the ICM would probably solve the issue.
        at least test it.
        • torq455
          • 1615
          or the crank position sensor. probably wouldn't be a bad thing to replace the ICM and coils. i have them, all new, and the OEMs are 15 years old with 159K miles. funny thing is...it's been 4 days without any problems.
          Andy
          • bigalwalker08
            • Oct 2009
            • 50
            I had this code on my 91 GP, It was the ICM... Also, It wouldnt hurt to put some dielectric grease on the ICM where the coils mount
            Alex (Big Al) Walker
            someday GM will pull its collective heads out of their collective asses and listen to us... or go bankru... oops.
            • torq455
              • 1615
              hell, if i do that, i might as well relocate the whole thing.
              Andy
                i see no reason not to.... anywhere is better than the stock location.
                • SofaKingWeToddDid
                  • Jul 2009
                  • 785
                  X2 had this code and pulled 3 or 4 ICMs out of the JY and first one i put on fixed the problem.
                  my car would die, like it was running out of gas, hitting the pedal seemed to make it worse, then like 5 minutes later it started. then one day it wouldnt. lol
                  • SofaKingWeToddDid
                    • Jul 2009
                    • 785
                    lol X2 on this as well. somehow i missed reading it
                    • torq455
                      • 1615
                      mine will start either cold or hot. it just starts weird and runs rough. so far, i've only had this problem during a cold start.
                      Andy
                      • SofaKingWeToddDid
                        • Jul 2009
                        • 785
                        you might as well replace them.
                        and if you plan on moving them, that gives you a chance to check on the condition of the wires too. if the wires are broken or have been pinched or something, it could cause problems like this too. code 42 is just aiming you in the direction. so somewhere between and including the ECM and the ICM you have a problem
                        • torq455
                          • 1615
                          it can also be a few wires. either a ground, a positive supply, or the EST wire.
                          Andy
                          • SofaKingWeToddDid
                            • Jul 2009
                            • 785
                            ...well... why are you telling me where you need to look? lol jk. but yes, you are right. if you move the coils though to a different location, then you might as well re do all the wiring related to is aswell. why not? then you know its guaranteed to work and be free of problems for a longer period of time. *unless you let some stupid old fuck that thinks he knows what hes doing work on your engine! haha
