Stumped By Coolant Leak
  • mpit91
    • Feb 2010
    • 2
    Question : Stumped By Coolant Leak
    I have a fast steady drip of coolant leaking only when the engine is at normal running temperature. Not exaggerating - about 3 drips a second. The leak is coming from the area right above the crankshaft. I discovered that it is dripping onto the belt and spewing everywhere in the vicinity of the belt.
    At first i thought coolant was leaking from one of the hoses or water pump. This is not the case. Then i thought coolant was leaking from the intake manifold gasket. I dont think this is the case because the leak just came on full force yesterday. It went from NO leak whatsoever to... "there is a little, but visible steam coming out of the hood when i am stopped"
    What could be some possible leakage areas?
    • 9189
    Timing cover gasket is my first guess, as I have had a similar leak and that is what caused it.
    • Weatheralls Auto
      Spinning out of control
      • Dec 2009
      • 536
      The bolts can also leak if they were not sealed properly.
      As of April 2
      Engine: 2006 SV6 3500 LX9
      Trans: 2002 Getrag F23 5speed
      Injectors: #36 GTPs
      TB: 65mm TCE
      Maf: 1999 3400 Montana.
      Beverages: Ice Cold CANADIAN.
