96 Buick Regal 3.1 where does cam sensor wire go?
  • GM Collector
    • May 2010
    • 5
    I am in the middle of doing the lower intake gasket and some tune up stuff. I have completed the job 99.9% but cannot find what plugs into the cam sensor pigtail. I can't find it spent all day pulled the upper intake back off still nothing. Even went under the car.
    The wire I'm looking for is the one right in front that runs along the head with the electrical tape on it.
    THIS PICTURE WAS TAKEN BEFORE I REMOVED THE LOWER INTAKE. THE MOTOR IS MOSTLY PUT BACK TOGETHER NOW.
    I see that it goes under the intake near the TB. I have looked at another 3100 motor I still could not see where it goes. I would appreciate any help I cannot find this connector!!!
    1994 Caprice Classic LS- LT1 swap, custom air intake, comp cam 1.6rr, comp cam springs, MSD cap rotor coil and wires, 2.5" turbo muffled dual exhaust dumped before the axle, 92 tails, tint and 5 spoke steelies on RWL tires - 4 10" Electro Voice speakers
    1994 Oldsmobile Silhouette - 1995 Oldsmobile 88 - 1996 Buick Regal
    • 9190
    That wire should be in the same harness as the fuel injector wires. I can't remember the plug config, or if there is a similar plug anywhere, but is there a chance you plugged it in to the wrong spot?
    Oh yeah, and welcome to the site!
    • GM Collector
      • May 2010
      • 5
      I checked that harness. I followed the wires to the injectors, MAP sensor, TPS and ECT sensor.
      • GM Collector
        • May 2010
        • 5
          • 13525
          I think the 96 achieva 3100 had it ran back by the alternator.
          • GM Collector
            • May 2010
            • 5
            I found the wire. I had it plugged into the EGR valve. The EGR plug was close by and I couldn't figure out where that went. I never thought I plugged it into the wrong connector. So this is a closed case, thanks guys.
