LA1 3400 permament LTFT -10...Injectors??
  • Zebe9
    • Mar 2004
    • 43
    It can only be within 0-1 volt so I am not sure what range you are talking about. It can read a range, just very slowly and still give you this type of result.
    i am talking about the fact an o2 sensor can give an output in range => amplitude
    1. 1xx-8xx
    and
    2. 2xx-5xx mV
    assuming the output changes w/adequate frequency in both.
    2nd example shows clearly inaproppriate behavior of the sensor.
    Zebe9
    Pontiac TS \'96 3400
    my way or highway
    • 86FieroSEv6
      • Feb 2010
      • 527
      Is the EGR valve leaking? On some models it's easy to put it on backwards and exhaust pressure will blow the valve off it's seat. Besides the readings you are getting, what symptoms is the vehicle exhibiting driveability wise?
      • Zebe9
        • Mar 2004
        • 43
        If EGR leaking...I got only Elm based scanner, it does not show even EGR commanded vs actual pintle position but no DTCs referred to such problem (so far)
        Driveability:
        - bad fuel economy (ca. 13.5 mpg)-> that hurts me much, in europe we dont have gas price like mineral water-as in States...
        - slight 'kicks' on steering wheel - like slightly uneven combustion, to be felt on idle/little load
        Zebe9
        my way or highway
        • Zebe9
          • Mar 2004
          • 43
          Then your Baro should be at or near 102kpa depending on the weather.
          Yep. Baro shows 101 kPa.
          Zebe9
          my way or highway
          • 86FieroSEv6
            • Feb 2010
            • 527
            You could temporarily place a piece of shim stock under the EGR to block it and see if that is the problem.
            • MidnightriderZ24
              • Jan 2005
              • 699
              #21
              besides the lean condition, how is the MAF radings from the sensor at idle? quick compression test/ cylinder leakage test could help. how do the plugs look?
              [SIGPIC]
              12.268@117... 11's to come!
              • Zebe9
                • Mar 2004
                • 43
                #22
                Both O2 sensors just replaced for new ones(NTK), MAF cleaned, flow on idle 3-4 g/sec, spark plugs just replaced(Autolite i suppose), old ones little blackish-too much fuel burnt ??
                I run bifuel=E95 and LPG, burnt out valve seats could be potentially next suspect but thats a bigger job and money to spend.
                Zebe9
                my way or highway
                  • 13531
                  #23
                  EDIT
                  Nevermind. Its in lb/min not grams. I didn't think 1 g/sec would be right but I remembered hptuners showing 1 only at idle.
                  • Zebe9
                    • Mar 2004
                    • 43
                    #24
                    EDIT
                    No, its OK,i just didnt switch to imperial units on my scanner, so 4 g/sec indicated and AFAIK -its OK.
                    Zebe9
                    my way or highway
