2005 Chevy Equinox 3400 coolant in enine oil
  • andytk5
    • Nov 2010
    • 27
    #31
    Originally posted by onefastV6 View Post
    You are probably going to be better off finding a used engine and dropping it in.
    Check http://www.car-part.com and see what you can find with low miles.
    Yeah it's looking like that fellas, still going to check out the machine shop just to make sure but I found one for $750 30mi away, bout the cost of a rebuild kit and I don't have to fool with it
      • 9188
      #32
      I just looked at my 3500 crank in the garage, and it doesn't have any markings similar to what you are showing on it. Oddly, it actually sent a rod through the oil pan, and bent another one into a crescent moon shape. Not sure on the cause, as I picked it up on ebay as a bad short block several years back.
      • andytk5
        • Nov 2010
        • 27
        #33
        Going to check two engines across town..
        • andytk5
          • Nov 2010
          • 27
          #34
          was there any warranty or recall for this engine based on GM's faulty coolant and gasket design? I have heard there was a case by case basis going on but nothing official.
          Yeah I have no idea about those crank marks, never seen that on any motor before either. Thanks for checking your crank for me too.
            • 9188
            #35
            Doesn't look like you'd be eligible though...
            • andytk5
              • Nov 2010
              • 27
              #36
              yeah I see, thanks for the info though. Looks like parting this thing out may be a viable alternative and just going with a new car.
              • andytk5
                • Nov 2010
                • 27
                #37
                couple engine across town, some are pontiac torrent engines. How can I find out the interchangeability of these engines. I mean if it only requires swapping intakes and oil pans then no sweat. Are there any computer interferences dropping a 2006 torrent motor into my 05 NOX? , should I swap my sensors?
                  • 9188
                  #38
                  Can't look it up right now, but I'll check out what changes came about for that engine between 05 and 06. It should be a relatively easy and direct swap though. I'll be able to look up the differences in a couple hours and post them up.
                  Droid via Tapatalk
                    • 9188
                    #39
                    The 2006 Torrent engine will be a direct swap with a 2005 Equinox.
                    • andytk5
                      • Nov 2010
                      • 27
                      #40
                      Thanks so much for that info man! I haven't posted back since I have been installing that engine actually, i have the engine in and just finishing the last bolts and wiring connections, One question though guys... Where can I fill the trans fluid and check the level?? I spilled some tanny fluid before and now need to top it off. I guess this is one of those trans that isnt owner serviceable but Im sure there is a way. Thanks so much guys!
                      • andytk5
                        • Nov 2010
                        • 27
                        #41
                        Everything is good except dash lights are flashing and have a car/lock symbol blinking, car must thing it is getting stolen. Gotta figure that out then all is good..
