3.4l starting problem?
  • ad1harvey
    • Dec 2010
    • 6
    Question : 3.4l starting problem?
    Alright so I am new here and have been trying to do some research to see if anyone can help me out here because I am at a loss so far. I have a 95 GTP and when starting in the mourning starts fine a good majority of the time but when starting any other time after that I have got to pedal the start as if it were carburated. Then when I do get it started after that I have got to crank it up to 1500 rpms for a while until it clears up. To go along with that issue the car idles rough until I drive it for a while then it clears up. Now I have already changed the idle air control and the intake manifold gaskets and am having no luck. Any suggestions?
  • ad1harvey
    • Dec 2010
    • 6
    I have also recently changed the fuel pump.
      • 9191
      Have moved responses to your other thread in the DOHC Maintenance section. Welcome to the site! Hopefully we can help you get your problem fixed.
