i have a 1994 oldmobile achieva and i have no spark i hooked up a scan tool to it and it said the crank sensor was bad! I relaced that and still nothing now i cant get a reading with any scan tool an dstill no spar what should i do???
1994 olds achieva no spark
Which crank sensor did you replace? On a 3100, there are 2 - 1 behind the pulley and the other on the back side of the engine. The one on the back (which is a PITA to change) is the one that sends the signal to the ICM and therefore controls spark.
By the way, welcome to the site!-Brad-
Could be the ICM or the wiring from the CPS to the ICM.
Droid via Tapatalk-Brad-
ICM is the module that the coil packs mount to. The wire goes between that module and the crank sensor (CPS) that you replaced.-Brad-
If your lighter doesn't work then your diagnostics port won't work. Check your fuses. I don't recall having a code for bad crank sensor...unless its for the one behind the harmonic balancer. What specific code was it? What kind of scanner are you using?88 Beretta GTU turbo . 90 Black ASC/McLaren TGP, awaiting 4t80. 2003 Grand AM se 3400/4t45 daily grind.
