1994 olds achieva no spark
  • coolaid
    • Mar 2011
    • 6
    i have a 1994 oldmobile achieva and i have no spark i hooked up a scan tool to it and it said the crank sensor was bad! I relaced that and still nothing now i cant get a reading with any scan tool an dstill no spar what should i do???
    • 9186
    Which crank sensor did you replace? On a 3100, there are 2 - 1 behind the pulley and the other on the back side of the engine. The one on the back (which is a PITA to change) is the one that sends the signal to the ICM and therefore controls spark.
    By the way, welcome to the site!
    • coolaid
      • Mar 2011
      • 6
      i replace the pita one lol i didnt know there were 2 of them
      but it will crank over and i had the coil pack tested and its good but still no spark
        • 9186
        Could be the ICM or the wiring from the CPS to the ICM.
        Droid via Tapatalk
        • coolaid
          • Mar 2011
          • 6
          how do i check that? and where are those located? if you know
            • 9186
            ICM is the module that the coil packs mount to. The wire goes between that module and the crank sensor (CPS) that you replaced.
            • coolaid
              • Mar 2011
              • 6
              k ill try that an see what happens if it wrks ill let you know thank you
              • TurboGTU
                • Dec 2003
                • 453
                If your lighter doesn't work then your diagnostics port won't work. Check your fuses. I don't recall having a code for bad crank sensor...unless its for the one behind the harmonic balancer. What specific code was it? What kind of scanner are you using?
