coolant leaking out the exhaust, replace head gaskets?
  • kill_them_all
    • Jul 2004
    • 96
    I have a 97 grand am gt with a 3.1, the car has 181,000 miles. The car leaks coolant out the exhaust and produces white smoke. The car idles fine. Is the problem the head gaskets? If so how hard are the head gaskets to replace. I know I will have to replace intake manifold gaskets, exhaust gaskets, and the egr gaskets. I already found the torque specs for the 3.1 on this site (thanks). Also can I rent a tool for torquing to the proper degree (90*). Any help will be great. Thanks.
  • kill_them_all
    • Jul 2004
    • 96
    The correct torque specs for this engine would be the 3x00 file correct? Thanks
    • robby1870
      Squaddoosh
      • 584
      Yes.
      Head gaskets arent too bad, just take stuff off, but it back on the way you found it
      Robby Whitesell
      2006 Pontiac G6 GT
      1985 Toyota Pickup DLX
      • kill_them_all
        • Jul 2004
        • 96
        should I use rtv sealer on the heads?
        Also I will have to replace the intake gaskets and exhaust gaskets correct and will I have to retime the engine? Thanks.
        • kill_them_all
          • Jul 2004
          • 96
          what else will I need besides this?
          egr valve and pipe seal
          intake gaskets
          distrib oring
          • RednBlack
            Wood Hippie
            • Mar 2004
            • 2795
            NO!! NO SEALANT on head gaskets!!! Bad! VERY BAD! They should have their own if needed. If you add any sealant to a head gasket, you deplete your torque value and take a serious chance of clogging a return hole or coolant passage. Do it according to the book.
            • ProjectMM
              • Mar 2004
              • 170
              it might only be the lower intake gasket, i've seen this many times. but if your going that far it's only a little further for the heads.
              2002 Pontiac GrandAm GT1
              3400 v6
              TOG headers
              RSM 62MM T-body
              FFP underdrive pulley
              GRANATELLI MAF
              Ported upper intake
              MSD DIS 4 ignition box
              MSD Wires and coils (pending)
              Venom high flow fuel pump (pending)
              • kill_them_all
                • Jul 2004
                • 96
                Project, will I be able to tell if its the lim before I take off the heads????
                Also will I have to re time my engine?
                Thanks.
                • dbtk2
                  • Feb 2004
                  • 349
                  You will not have to re-time it. Its a pushrod engine, so you won't be touching any cams or anything during this project.
                  Shawn
                  99 Grand Prix GT
                  • kill_them_all
                    • Jul 2004
                    • 96
                    Thanks, Shawn.
                    Also does anyone know the name of the tool used for torquing a bolt to a certain degree (ie- head bolts 90 degree turn).
                    Thanks.
                      • 9190
                      You use a torque wrench to torque to the proper spec. Then, to go to the 90 degree, you continue to turn the torque wrench 90 degrees past when it clicks (hits the specified torque). There really is no special tool.
                      • kill_them_all
                        • Jul 2004
                        • 96
                        Thanks bszopi, I am really appreciating the support guys and or gals.
                        Is there anything I should be aware of when before I preform these tasks?
                        I know it will take time, I have the time (about a week), and I can just let it sit in my yard till I get it done.
                        • bud36light
                          • Nov 2003
                          • 517
                          I marked the bolts with paint then turned them 90
                          2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
                          • kill_them_all
                            • Jul 2004
                            • 96
                            Anyone in Illinois want to come help me??? nah, I'll be fine.
                            Do I have to seal the upper and lower intake gaskets with anything?
                            • bud36light
                              • Nov 2003
                              • 517
                              Nope. No sealant. Where you at ?
