Help please !!!!!!!
  • sheila cutlass
    • Jun 2012
    • 5
    Resolved : Help please !!!!!!!
    was running ruff no power station said its not worth it but i have no money so its gonna have to be worth it a friend told me about you guys please help my neighbor took off the top of engine (plenium???) said maybe a lifter is bad also said it needs plugs and wires didthat reassembled and no start no gas pressure at rail will run poorly for a few minutes if i spray starter fuild into air cleaner guy is good guy but lost any idea? once it runs ill have lifter looked into
    • 13534
    We aren't grammar nazis, but if you want us to understand you, slow down and use punctuation.
    No fuel pressure...replace fuel pump or check filter to make sure it isn't plugged up.
    • sheila cutlass
      • Jun 2012
      • 5
      removed filter not clogged pump spits out gas when i crank maybe fuel regulator im lost
        • 13534
        Pull the vac line off the regulator and put a vacuum gauge on it. If it holds pressure, that isn't it. Just because the pump is flowing fuel, is not a sign that it is strong enough to allow for pressure. I had a bad pump do this before.
        • sheila cutlass
          • Jun 2012
          • 5
          will do thank you for the help
          • sheila cutlass
            • Jun 2012
            • 5
            no vacuum guage any other way to check it like i said thanks again i am really broke thanks again
              • 13534
              does the vacuum line smell like gas? Pull it off and start/crank the car. See if its wet at the vac port.
