car runs like crap when you apply any power when warm
  • geldartb
    The Situation
    • May 2004
    • 1994
    ok here it is ive done almost everything to this car i replaced the
    pcv valve
    swapped out egr (took it apart and cleaned all the carbon out)
    cleaned out the intake(minor p&p job done by myself on the upper)
    tps sensor
    map sensor
    new plugs and wires even the coils too msd ones they were the same price
    changed fuel filter
    swapped out the vacum cannister that plugs into the front of tranny
    injectors professionally cleaned out
    all this stuff helped out alot i even got a nice power gain accross the whole powerband but when it warms up like you have been driving for a little while and you start to drive it hard like a 0-60 run or something like that it develops a sputter that can be sometimes cured by shutting the car off for a few and restarting it but then it comes back again with the more agressive use of the gas pedal. someone told me that if i replaced the catalytic converter that it would help it out or would hollowing it out just to see if it helps the problem of course and buying a new one if needed please help ive done everything to this car.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
  • ProjectMM
    • Mar 2004
    • 170
    that or an O2 sensor stuck lean, but the cat would be a really good idea! Ps what's the year make and modle?
    2002 Pontiac GrandAm GT1
    3400 v6
    TOG headers
    RSM 62MM T-body
    FFP underdrive pulley
    GRANATELLI MAF
    Ported upper intake
    MSD DIS 4 ignition box
    MSD Wires and coils (pending)
    Venom high flow fuel pump (pending)
    • geldartb
      The Situation
      • May 2004
      • 1994
      95 beretta z26 3100 o2 sensor is only a few months old so it shouldnt be that but the cat has probably a 173000 miles on it.
      99 Grand Am GT
        • 13499
        My fuel pump would do that when the engine got warm and the hot gas got recycled to the tank. The brushes in the pump were worn and shorting out when it got hot, which made the output considerable less than what it should be. Thats another possibility (mine was real bad, you couldnt floor it without it bogging all to hell).
        Other idea is the coil packs putting out less when they get hot.
        • TheDirtyBen
          • Mar 2004
          • 130
          i vote for fuel pump or timing set. my car would run fine for about 5-10 minutes, but when it warmed up i started missing cylinders and limp along. new fuel pump solved the problem.
          1994 Oldsmobile Achieva (2002 3100 SFI)
          Homemade ram-effect CAI
          K&N cylinder filter
          Poorboy Lowering Kit
          Front STB
          • geldartb
            The Situation
            • May 2004
            • 1994
            how much do you think it would cost to get a new fuel pump installed giving the price of the pump and the labor which is usually 50 an hour
            99 Grand Am GT
            • TheDirtyBen
              • Mar 2004
              • 130
              i paid like $80 for my pump @ auto zone. labor is prolly about 2 hours.
              K&N cylinder filter
              Front STB
              • geldartb
                The Situation
                • May 2004
                • 1994
                thanks for the help guys getting the pump replaced at the end of the week also i changed out the o2 cause it had a lifetime warrenty so now i got 2 o2 sensors that work good. when they changed the fuel filter cause i couldnt get it off they showed me the gas and it was dark brown. thanks for the help these forums help out alot plus the people help too
                99 Grand Am GT
