coil pack/fan removal questions
  • englundjd
    • Jan 2013
    • 31
    Question : coil pack/fan removal questions
    Ok so i found the bolts for the fan, took them out, unplugged the fan motor, and started trying to remove it only to find that i cant get it out from the top because the exhaust manifold is in the way and there seems to be no way to get it out from the bottom either. How do i get this thing out?
    Also on the coils themselves, there is 3 bolts right? i found one but i cant find the others lol. This car has a good amount of miles and everything is dirty as hell which is making this rather frustrating
    91' Cavalier z24 A3: cai, muffler (no fart can)
    94' Camaro z28 A4: turbo build commencing
    94' Firebird Formula A4: LT1 355ci, cam, stall, gears, bolt ons, tune
    98' Monte Carlo Z34 A4: stock
    07' Impala LT A4: stock
    i seem to remember two bolts holding in a coil pack.... one on top, one on bottom, more or less centered.
    • englundjd
      • Jan 2013
      • 31
      ok that would be helpful i was going to remove the icm with the coil packs on it but i cant get the fan out of the way so i may just have to do the coils
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        IIRC if you have weak motor mounts, you can jack the engine up just enough to clear the fan motor. Or you can remove the fan motor. As always prior to most repairs, disconnect the battery.
        • englundjd
          • Jan 2013
          • 31
          ok ill try that^^
          Ok so i got the fan out, I took the 3 bolts out (2 on top 1 on bottom) and then i took off the coolent hose that runs from the thermostat to the radiator. and slid the fan shroud over and pulled really hard lol
