Transmission Swap
  • Jesster
    • Apr 2011
    • 41
    Question : Transmission Swap
    A friend has a 95 Lumina with a 3100 (blown head gasket, fairly rusty vehicle) and another friend has a 1998 Lumina with a 3100 and a blown transmission. Can the transmission from the 95 Lumina be put into the 1998?
    I understand that the 4T60-E was replaced with the 4T65-E transmission in 1997; were they identical at least from an installation standpoint?
  • fat rabbit
    • Jul 2013
    • 44
    1995 and 1998 L82(small port 3100) equipped Lumina's only came with 4T60E transmissions stock, I be leave it was the LTZ Lumina that changed over to the 4T65E in 1997 but the base and LS model L82(small port 3100) Lumina always had a 4T60E stock.
    With that being said there the same transmission and should bolt up identical.
    1997 Chevy Lumina LS- SOLD
    Mods:3400 cylinder heads, 01 upper & lower intake, 56mm throttle body, 22.5lbs injectors w/ 55psi regulator, 1' 3/8" thick radiator, tuned with lower fan temps by wot-tech
    2010 Chevy Impala LT
    Mods: LGD swap, 3.29 standard duty differential, 33 37 drive sprockets, Don Rome brackets, front and rear GMPP strut tower braces, GMPP 22mm front sway bar, GMPP 19mm rear sway bar and tune from Over Kill Motorsports
