Timing Chain Cover Gasket
  • Jesster
    • Apr 2011
    • 41
    Question : Timing Chain Cover Gasket
    I have a 1998 Lumina LS with a 3100. The timing chain cover gasket is leaking coolant again. I have the cover stripped of parts except I can't get the key out of the crank and of course the cover won't slide over the key. I also need to replace the crank seal while the cover is removed.
    Any tips to get the key out of the crank and tips on replacing the seal?
  • caffeine
    • Jan 2012
    • 1489
    I've never had to remove the key to get the cover off. As long as the balancer is removed the cover should come off just fine
    '86 Fiero, 3500, 4-speed
    • Guest
      This ^^^
      The key in the crank will slide through the opening in the front cover just fine, there's lots of space.
      A picture of what you're dealing with might help clear up what your problem is exactly.
