does injector length make a difference?
  • cutlass supreme FE3
    • Nov 2008
    • 225
    Question : does injector length make a difference?
    anyways 4 of the old injectors read less than 11ohms so I got 6 to replace them.
    now the problem i have is that the original ones from the car seem to be 3-4mm longer at the nozzle than the new ones. Should I be concerned?
    I did not know they have options for shorter or longer nozzle tips.
    • Nov 2008
    • 225
    you can see the total length of the old vs the new
      • Nov 2008
      • 225
      side by side picture
        • Nov 2008
        • 225
        much shorter but will it not seal up?
          should be okay. the longer injector appears to have move ring "slot" length and the o-ring looks like it would end up in the same location anyways.
            • Nov 2008
            • 225
            but the o ring ends up a tad higher
            there is no way to lower the fuel rail? nothing to adjust?
