voltage messed up
  • geldartb
    The Situation
    • May 2004
    • 1994
    voltage messed up
    ok on the way to work sunday morning i noticed my voltage pretty low like when you just turn the key on to ge stuff powered but not actually tunring the car on so i changed the alternator solved the problem till about 7 monday night when i noticed my lights were kinda dim i looked at the gauge and the needle was in the same place. so pretty much its running off the battery without charging it. last night it died on me in my driveway could this be a computer prob because i have 2 computers from the same year car with all the same stuuf in it smae typr of car but the numbers are different. any help would be good
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    You didn't use the new alternator to charge the battery did you?
      • 13534
      Check your power and ground cables. The battery may be the culprit killing the altnernators too.
      • RednBlack
        Wood Hippie
        • Mar 2004
        • 2795
        Originally posted by SappySE107
        altnernators
        Whew!! Typin' too fast? Jus' pokin' fun!
        • geldartb
          The Situation
          • May 2004
          • 1994
          when i changed the battery out the first time i just bought a new battery cause it was after that really cold winter. both batteries were fine one was a yellow top and the other was a interstate both heavy duty ones. battery cables look fine no corrosion on the ends that meet the car
          99 Grand Am GT
          • RednBlack
            Wood Hippie
            • Mar 2004
            • 2795
            My point is, the alternator keeps the battery charged, it is not meant to charge a dead battery. It overloads the voltage regulator. You might get by sometimes, but not too often. When you change the alternator, charge the battery.
            • geldartb
              The Situation
              • May 2004
              • 1994
              last night i changed the battery cause my car died right across the street from my house .so it should be ok with the different alternator considering its already charged. even so im charging the other battery i got so well tyr that tomorow morning.
              99 Grand Am GT
              • robby1870
                Squaddoosh
                • 584
                It wouldnt surprise me if the alternator isnt toast again. I had a spell on my old 92 where I went through 4 alternators in less than a year
                Robby Whitesell
                2006 Pontiac G6 GT
                1985 Toyota Pickup DLX
                • geldartb
                  The Situation
                  • May 2004
                  • 1994
                  the last 2 were junkyard alternators cause i didnt have the money to buy a new one. time to find one of the ones with a lifetime warrenty wouldnt really surprise me either but i dont even have my stereo hooked up in my car so theres no huge power drains from that.
                  99 Grand Am GT
                  • robby1870
                    Squaddoosh
                    • 584
                    I didnt have any stereo stuff in my old 92, just a head unit. All my alternators had some sort of warranty, so they were free when they broke. I had one break, and I mean, disintegrate, 15 min after I put it in. I was around 4K rpms, and I heard a loud pop, then grind, and my charge light came on. Took it off, pieces fell out of it, LOL
                    Robby Whitesell
                    2006 Pontiac G6 GT
                    • geldartb
                      The Situation
                      • May 2004
                      • 1994
                      well i got a new alternator everything seems fine ill let you guys know how it works out throught the night everything seems normal
                      99 Grand Am GT
                      • geldartb
                        The Situation
                        • May 2004
                        • 1994
                        everything seems to be back to normal now hopefully this one will last longer
                        99 Grand Am GT
