Thermostat questions.
  • TheProfessor
    • 869
    if your cap isnt sealed your coolant will boil at 45 degrees cooler than if it is and if you have a 50/50 mixture thats not very hot
    the purpose of the cap is to increase the preasue which increases the boinling point 3 degrees for every psi
    most caps are 15 psi it a very important part of the cooling system
    I Like V660s
    Does Chevy make beer
    ~Jayme~
    • barkat
      • Oct 2004
      • 14
      I agree 100%. That is why I thought you were saying that, just wanted to make sure. So any more ideas?
      • TheProfessor
        • 869
        well if you run it
        wont the pressure push the air to the coolant tank
        then you can get it out that way
        you know just take the cap off a little till you start hearing it hiss
        be carefull though and do it slow
        I Like V660s
        ~Jayme~
        • TeeJay3800
          • 49
          Originally posted by barkat
          HEY TEE JAY3800! I just called my local parts guy and asked for a mid ninties camaro stat for the 3.1. He said "yep, got one right here, 195 degree!" Maybe I need a different year?
          Ummmm.....mid 90's Camaros didn't have the 3.1L. Sounds like neither one of you know what you're talking about, lol.
          I asked for a '90 Camaro 3.1 at Advance and he gave me a 180° Stant SuperStat. Try asking for a 90-92 (only years the F-body got the 3.1).
          \'90 Cutlass Supreme SL coupe - 3.1L LH0 V6/HM 4T60 -- every factory option
          Flowmaster 40 - no cat // K&N FilterCharger // KYB GR-2\'s // Stant 180º SuperStat
          • bu01
            • Apr 2004
            • 91
            Shop performance car parts online at PFYC.com! Explore aftermarket & OEM parts like camshafts, spoilers, turbos & more — shop now!
            • barkat
              • Oct 2004
              • 14
              #21
              thatsbwhat I needed, thanks. Any tips on getting that air out now?
                • 13528
                #22
                Use the bleeder screws. Im not sure on your particular setup but mine has 2. One near the T-stat, and another on the heater core return line near the firewall. I bleed the lower one first and then the upper one (heater return sits higher). I have also heard of just putting the car up on ramps and running it for a bit with the cap off.
                For bleeding, get the car warmed up so there is pressure in the system, then open the bleeders slowly till you hear it hiss. It may just spit fluid out but you want a solid stream, then close it. That should pretty much cover you on the bleeding.
                • bu01
                  • Apr 2004
                  • 91
                  #23
                  no brob
                  • Juglenaut
                    • 1130
                    #24
                    Whats a bleeder screw 0-)_
                    I am back
                    Mechanical/Service Technican
                    • barkat
                      • Oct 2004
                      • 14
                      #25
                      TA DAH!!!!!! Well I went to another parts store today and told them "I want a thermostat for a 90 Camaro with the 3.1L!" What do you know, I got a 180 degree stat made by Stant. I also found out that the other places I was going to had Stant stats, but in there own boxes, and thats why the numbers wouldnt match up. Any way I got the new stat ( by the way it is Stant #13848 ) and a new seal, so I guess this weekend I will try this again. Thanks for all the help everybody.
                      • TeeJay3800
                        • 49
                        #26
                        What'd I tell ya!
                        • geldartb
                          The Situation
                          • May 2004
                          • 1994
                          #27
                          ok is there any real differenve between this one 45848 and this one 13848 one is a heavy duty thermostat and the other one looks to be a normal duty just wanted to know before i put it in my car btw 95 3100 this is the thermostat you guys said would work in the 3100 its a 180 for a 90-92 camaro rs
                          99 Grand Am GT
                          1357 cam 227 233 .050 dur
                          515 515 lift 112 lsa
                          • barkat
                            • Oct 2004
                            • 14
                            #28
                            Well, not that I can tell. I have been running about 120 miles a day for about a month with no real problems. By "no real problems" I mean I think I still might have a little air left to bleed out. At the same time though, I havent been bleeding it at all, just driving it.
