head gasket blown
  • acascianelli
    • Oct 2004
    • 24
    head gasket blown
    well, after putting over 62000 miles on it since i bought it at 57000 miles my head gasket blew. ( it has a little over 119000 on it ) the leak is on the back 3 cylinders on the drivers side, just above the transmission. coolant is leaking out and burning off as it hits the transmission.
    anybody have any idea how much it will cost to have the head gaskets changed and have the heads reworked. on top of the head gasket my transmission has been afting weird. grinding when it goes into reverse and shifting very hard into 2nd.
    im not sure what im going to do with the car yet, being that both the engine and transmission are screwed i might just cut my losses and get a new car.
    1994 Pontiac Grand Prix 3.1L
  • korbendallas68
    • 3400swap.com •
    • 553
    At a shop, the gasket work alone will be $500+
    1995 Grand Am GT
    3400 V6 / 4T60-E / Engine Swap
    3400 Engine Swap Guide Version 2.5 is Available!
    www.3400swap.com
    • acascianelli
      • Oct 2004
      • 24
      is it possible to change the head gaskets without pulling the motor out of the car?
      • robby1870
        Squaddoosh
        • 584
        Yup, sure is
        Robby Whitesell
        2006 Pontiac G6 GT
        1985 Toyota Pickup DLX
        • korbendallas68
          • 3400swap.com •
          • 553
          Yeah, thats about the only way you should do it is with the engine in the car. IMO it's not that hard, its just the little bitch stuff that you forget to do after you get back together, and realize you didn't do it...
          But you might want to make sure your transmission is ok first... before you go and throw all that work and money just find out your trans is worthless. Replacing the transmission is a lot more work.
          1995 Grand Am GT
          www.3400swap.com
          • acascianelli
            • Oct 2004
            • 24
            the problem with the transmission may be just a bad vacuum modulator. ive been looking at how to remove the heads on the 3100 and one of the parts im unsure about is removing the rear exhaust manifold. it says that you have to loosen the subframe bolts and bo about doing it that way.
            • korbendallas68
              • 3400swap.com •
              • 553
              I think thats so the exhaust piping can drop down a bit so you can remove the head... Not sure about that though. You are going to want to ask Brad that one.
              1995 Grand Am GT
              www.3400swap.com
                • 9185
                I've never seen anything about subframe bolts when it comes to head gaskets. As far as the exhaust goes, all I have ever done is just disconnect the downpipe from the exhaust manifold and pull the head with the manifold still attached. I tried once removing the exhaust manifolds from the heads so I could just pull the heads, but it was just a big waste of time.
                • acascianelli
                  • Oct 2004
                  • 24
                  well, since it is my only car and i needed it fixed right away i took it in to get fixed. thatll set me back 1100-1200 just in time for christmas.
                  • korbendallas68
                    • 3400swap.com •
                    • 553
                    holy geez! $1200!! There's no way I'd pay that outragous price! Crazy. :wtf:
                    1995 Grand Am GT
                    www.3400swap.com
                      • 13513
                      wow...thats a rape and a half on that one.
                      • DEI37
                        • Jan 2004
                        • 516
                        Yeah, no kidding. When I had head gaskets done in my 3100 powered Cutlass Supreme, I paid $450.
