Dashboard temperature reading
  • BoringLumina
    • Oct 2004
    • 32
    Guys,
    Since I have been having problems with water getting into my oil it has got me paranoid about the head gaskets.
    Robby answered that the dash temp comes from the rear head. I see the sensor and it is at the corner of the head below the EGR valve. What I am wondering and worrying about is this. That temp sensor is on what would be the outside of the water passage and I know that my water level was really low so even if the temp gauge never went into the red (actually never more than 3/4 of the way) I am wondering if the heads could still be warped?
    OK. I see from the sensor section that there is also a temp sensor near the thermostat. That one is what the computer uses for running the engine right? So the second one is a back-up? Would either one getting too hot turn on a dash light?
    I am going to replace intake gaskets and re-torque using thread lock and if that doesn't work its off to the charity lot with BL.
    Boring Lumina is a White 4-Door with 191,000 miles on a 1995 3100 V6. No mods and only minor repairs so far (Hoping the repairs stay to a minimum) Why yes, I am an
    • 13533
    The computer doesnt see the 2nd one for the dash, so its not backup. Do a compression test if you are worried about the head gaskets. You need the pushrods installed but the lower intake can be off for this.
    • BoringLumina
      • Oct 2004
      • 32
      OK, so you are saying that the engine control one, the one at the thermostat is the one that would make the idiot light come on?
        • 13533
        Yup, the computer doesnt know the other exists.
