anyone EVER seen this??!
  • treeZ24
    i wanna go fast!
    • Mar 2004
    • 251
    has anyone ever come across this problem in a alum head 2.8L?>>>???!!!!
    in both heads in the middle combustion chambers right above the valve seat of the intake valve ( on the side which connects to the exhaust valve side)
    there's a freakin hole through to the water jacket!!!!!!!! thats why my compression was 125 psi compared to my other readings of 170 and 165 for that head!!! and all this time i thought it was the head gasket just finally went..i'll try and get pics up hopefully i can get them checked out... i already decked em .020 soooo unless this is going to cost me more then a different head and THAT machining i'm stuck with it
    got zap-straps?
    89 Z24
    13.886 @ 96.16 mph
    street trim - slicks
  • Rhedalert
    Dr. Feelgood
    • 1574
    I haven't seen that happen before. The hole on the other head looks the same too???
    Brian
    3400 SFI V6, 4T60e
      • 13534
      Ive seen a crack between the seats before, and a burn through hole on an exhaust valve in a DOHC, but never a hole like that. Only way to repair it is welding I bet, and thats going to take a professional to get that job right. I wouldn't recommend using them if you can't get it fixed either.
      • geoffinbc
        Iron Head Enthusiast
        • 5831
        Does the hole really go into the water jacket? I didn't think it would come that far down towards the combustion chamber.
        • robby1870
          Squaddoosh
          • 584
          Wow.....thats odd. Never seen that before, especially since its not a crack, but more a pinpoint hole.
          Robby Whitesell
          2006 Pontiac G6 GT
          1985 Toyota Pickup DLX
          • DEI37
            • Jan 2004
            • 516
            Yeah, that is goofy. You're not missing a chunck out of a piston or a valve, are you?
            • treeZ24
              i wanna go fast!
              • Mar 2004
              • 251
              no, no engine parts are misformed :P.. not at all, and the more i think about it its just gotta be too much of a coincidence.. ie casting flaw
              do i hope it doesnt go into the water jacket??? yes :P i haven't had it pressure tested yet but i'm almost positive unless the head gasket was just blown as well.. ( water system pressurized BIG time ) there is a hole.. now another issue i have is that (if it IS a hole) that there is a possiblilty that it might not show up on a pressure test.. but needs heat in order for it to start leaking.
              *sighs* all i can think about right now is my 3.1/3400 hybrid =/
              got zap-straps?
              89 Z24
              13.886 @ 96.16 mph
              • geoffinbc
                • 5831
                My dads seen it . He agrees it is a casting flaw.
                • sharkey
                  • Jun 2004
                  • 2061
                  dont you still have one good head from your other motor you can slap on there till your hybrid is done??? i wouldnt want to put that back on, even if it checks out ok. it can will become a hot spot and can cause detonation, and may torch it right through inot a water jacket.
                  • TheProfessor
                    • 869
                    ive seen lots of cracks from over heating repeatedly on my old 3.1 heads
                    but nothing like what you have there never
                    I Like V660s
                    Does Chevy make beer
                    ~Jayme~
