Dead engine
  • ADub02
    • Dec 2004
    • 3
    Dead engine
    New to the board, thought you guys could help me out.
    93 Lumina 3.1 210,000 miles. Driving the car today, ran fine. Left a stop sign and car had very little power, made it about 150 ft then oil light came on, then check engine light, then it just died. All in all about 300 ft from the stop sign. I can hit the starter, but it sounds odd. All the accessories turn including the crank pulley when i hit the starter, but the engine doesn't move. Pulled the oil cap, no valve movement. Put a wrench on the crank pulley and it seemed to turn pretty easy. Any idea? I figured it either spun a bearing and trashed the crank or the timing chain broke. If the timing chain broke, is this an interference engine?
    Thanks
    AW
    • 13534
    RE: Dead engine
    Its interference but it may not have bent a valve anyway. Sounds the chain to me, not turning the cam, not pumping oil, and the oil pressure sensor will then kill the fuel pump (or should). Gonna have to tear it down and see what damage you have though.
    • robby1870
      Squaddoosh
      • 584
      RE: Dead engine
      I'd say chain too, just by what you said about crank turning over, valves not
      Robby Whitesell
      2006 Pontiac G6 GT
      1985 Toyota Pickup DLX
      • DEI37
        • Jan 2004
        • 516
        RE: Dead engine
        Yup, gonna go with a broken chain, or cam. Most likely, the chain.
        On a side note...the 3.1 MPFI is an interference, Ben? This is definitely news to me. I know the 3.4 DOHC is supposed to be, but the 3.1?
          • 13534
          RE: Dead engine
          DOHC is not except 96+ MIGHT be. pushrods are last I heard. It might depend on which puishrod though cause the pistons changed over the years. The dished 3.1 stock pistons may allow it to have clearance.
          • TheProfessor
            • 869
            RE: Dead engine
            yup new timing chain time
            I Like V660s
            Does Chevy make beer
            ~Jayme~
            • ADub02
              • Dec 2004
              • 3
              Can I get to the timing chain from the pass side fenderwell or will I have to pull the engine?
