Hey guys! Been a while!
  • cypher_2001
    • May 2004
    • 35
    Anyways, I doubt any of you remember me. I have since traded my 00 malibu in for a 00 camaro 3.8. Before you start flaming, I am here on behalf of a fellow F-Body/60 degree v6 owner. He is having a problem with his and I thought this is the best place to get him some help.... Here is his post from our site. If you guys can help, I would really appreciate it!!Sorry about the length....
    I have been having an on going problem in my 94 3.4. A few years ago I pulled it out of storage and started driving it, after two days driving I blew a head gasket, I parked it, I finally got around to changing the gasket I put it all back together runs fine except I had a vaccume leak on my intake, I take the intake back off I find a collapsed lifter, I pull the lifter out run a indicator down the lifter lobe and check the lift on my cam and it had considerable amount of wear on it. I had someone give me an edelbrock performer cam for a 2.8 so I put that in since it was a 60 degree motor as well. I get it together and it runs like garabage. backfires under acceleration, I pull the cam back out and put in a stock replacement, still runs like crap, runs a little better now, doesnt backfire under acceleration just idles a little rough and accelerates choppy acts like it is not getting enough fuel, I change the fuel filter, I checked the fuel pressure and everything was okay. I just replaced the fuel injectors, the car is running way to rich the plugs are black. my question is someone told me that the computer needs to be reset, and it has to be taken somewhere that they can hook up to a programmer and reset it, but I always thought that on pre 96 that you just diconnect the battery and the computer would reset after a half hour. This person said that the cam that I had in it screwed up the computers settings and thats why it is running rough. I have to trouble codes or anything. Please help!
    If it doesn\'t go fast, make it!!!
    • 13533
    RE: Hey guys! Been a while!
    The computer isn't getting screwed up from that cam if you pulled the fuse or battery. Only takes 10 seconds, well, probably 2 but lets just say 10 for good measure. The 2.8 cam should have been fine so unless the pushrods are in wrong, the wrong length for that cam, or the cam is set wrong, I don't know why the cam itself would be causing those problems.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      LOL No the computer does not need to be reset. Thats the bigest load of shit I have ever herd. You may find a slight hesitation or studder while a computer does a little remaping for a different cam. Besides that Edelbrock cam is nothing a stock computer would work just fine with it.
      How did he adjust lifter preload on the engine? Have you run a compression test? Do you have your firing order correct?
