Bad lifter, or cam?
  • helrazer83
    • 2
    Bad lifter, or cam?
    My first post here...good to be among GM fans
    Anyway, I am currently replacing the head gaskets on an 88 Beretta GT that I recently acquired for the right price. 2.8, auto. After I got it tore down, I saw that this motor is in really bad shape. Grime and buildup is covering EVERYTHING in there. The result of several missed oil changes i guess. I noticed that one of the lifters isnt riding the camshaft quite right. You can see where the lifter is riding the lobe...its prolly 1/8" wide....or maybe 20% of the area it SHOULD be riding. (these measurements are very approximate...i will happily provide pics) The rest of the lobe is covered with grime that has obviously been there for awhile. So i pulled the lifter, and there is no obvious external damage. What could cause this problem? A bad camshaft? Or is something awry inside the lifter? I did notice that the lifter was extremely hard to remove, if that makes any difference. Any help would be greatly appreciated.
    I\'m allergic to rice.
    \'95 Monte Carlo Z34, 3.4 DOHC
    \'88 Beretta GT, 2.8
    • 13534
    RE: Bad lifter, or cam?
    Maybe the lifter isn't spinning properly? Considering the cost on ebay now and then for a new cam and lifters, I would replace them all. For that matter, I would probably clean that sludge out and put new bearings in there. Depends on what you are doing with the motor though. Daily driver, beater, project car? Pics would be good....though I can't say I enjoy seeing our motors neglected. I had a 2.5 that was caked in sludge.
    • helrazer83
      • 2
      i'll post some pics as soon as the snow/sleet lets up around here. This will most likely be a beataround or daily driver. I had the same thought as you...better safe than sorry and replace everything,( it would suck to replace the lifters, put the whole thing back together, and the camshaft was shot all along!) but i dont have a garage and its gettin pretty cold around here I figure i'll just pull the heads and work on em inside through the winter, and see how things develop this spring.
        • 13534
        http://cgi.ebay.com/ebaymotors/CHEVY...18926803QQrdZ1
        Just saw that looking through ebay.
        • Juglenaut
          • 1130
          Did you look at the cylinder walls?? tell me if you see a shiney finish or not...Can you see hone marks???
          I am back
          Mechanical/Service Technican
