3400 Intake Gaskets-Which are better?
  • clubairth
    • Jan 2006
    • 2
    I have a 2001 Monte Carlo with the 3400 V-6 and it has the dreaded intake leaking anti-freeze. After reading this board it seems that 2 brands of gaskets are being used to permanently solve this problem.
    From GM I have a TSB #03-06-01-010B that lists an "improved" gasket part #89017279 along with new long and short intake bolts. List is about $60 plus the bolts at about $4 each.
    FelPro makes a "Problem Solver" gasket kit. Part #MS98003T. List about $75. I looked at this in the store and it seems to have a very nice metal reinforced gasket and even comes with it's own small tube of silicone sealer.
    I want to use the Fel-Pro set but can anyone tell me the difference or what they use?
    Thanks for the help!
    Kevin
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    If the Felpro gasket has the metal inserts around the bolt holes then go for it.
    • gboogie99
      they still can't catch me
      • Nov 2005
      • 348
      what store carries the fel-pro gasket? I checked advance auto and they only had the original styled gasket
      • tractorman
        • 451
        Sometimes the folks at those cheap autoparts stores aren't the sharpest tacks around. I got that same set MS98003T from Advance, but I was told at first that they couldn't get it (it was in the computer, but the dumbass said he couldn't order it). I called the next day, talked to a manager and gave them that part number- they had it for me a couple days later.
        • Syn
          The Master Piece
          • Oct 2005
          • 599
          get the 3500 lim gaskets they are even better
          • John Michael
            • Feb 2006
            • 13
            The fel-pro gasket is all-metal. It is very nice. I got mine at www.rockauto.com for about $75 w/ shipping. Also comes with valve cover gaskets, EGR gasket, etc.
            • tractorman
              • 451
              That's a hellofadeal. That set cost me $105, and I had a hell of a time finding it. It doesn't come with an egr gasket though. You gotta buy a few more things besides the set. See my Holy Intake Gaskets board.
                • 13500
                The 3500 lower intake gasket wont work on a 3400. The plenum gaskets will but the lower to head won't match up.
                • Syn
                  The Master Piece
                  • Oct 2005
                  • 599
                  hmm i was told by countless reliable sources hmm looks like midnight is wrong lol
                  also the dealer has these gaskets here for a lil over 60 you guys are paying a lot
                    • 13500
                    The 3500 lower wont bolt up to 3400 heads, so there is no way the gasket is gonna match up right either. Ok...it bolts up but it doesn't line up with the intake ports properly:P
                    • Syn
                      The Master Piece
                      • Oct 2005
                      • 599
                      hey i didn't say i didn't believe you just saying what i was told. thanks for clearin it up
                        • 13500
                        Those metal plenum gaskets are HUGE! I dunno if gasket matching to that size is a good idea or not. Something else to mess with later on with dynomation. It can compare intake runner taper, and those gaskets would allow it to be opened up quite a bit.
                        • gboogie99
                          • Nov 2005
                          • 348
                          maybe the advance i go to still has the older gaskets, because i have still not been able to get any metal intake gaskets...
