Adding a DOHC windage tray
  • GutlessSupreme
    • Nov 2004
    • 166
    asdf
    -Tony | gtsdurango.net
    '04 Dakota Quad Cab SLT 4x4 - the gas guzzling DD.
    '90 Turbo Grand Prix STE - ehh.. I'm working on it.
    '92 Gutless Supreme SL - RIP 5.2010
    '90 Turbo Grand Prix - RIP 6.15.2005
  • GutlessSupreme
    • Nov 2004
    • 166
    anybody?
    • farmerz24
      • Feb 2004
      • 361
      hi, here is my input.
      i have resused/retorqued the stock rod bolts/nuts on 3.1 and 2.4 4cyl. no failures yet but the guys who like to do it properly would probably say you need to replace them. depends on the application i gues.. you are also supposed to replace your head bolts but ive gotten away with re-using them atleast once. (after that its time for a new set, or a set from a fresh motor). again the guys who do it proper will probably cringe for saying this but this is what i have done and havent seen a failure from it.
      for the windage, why not use a 3100 windage over the dohc? is the windage differnt? and you will probably need the main studs with nuts to hold the tray on (sory i dont have the part #). nor do i know how many you need... sorry thats all the info i have for u
        • 13533
        3x00 windage tray doesn't fit a DOHC or gen 2 motor without modification. Easier to just use the DOHC windage tray on these motors. You should replace the rod bolts and caps, main bolts, and head bolts. I dont have part numbers for them though but a dealership can get you the numbers.
        • farmerz24
          • Feb 2004
          • 361
          replace the rod bolts "AND CAPS"????
          isnt replacing the caps a little extreme, or did you mean something else, i mean if you are meant to replace the caps each time how is this any different than any of the other parts, such as the heads, oil pan, etc...?
          these of course can be removed indefinately without being replaced, what makes the caps so speical? unless you meant something else.
          let me know
            • 13533
            I meant the rod nuts with the bolts. I thought those were referred to as caps.
            • GutlessSupreme
              • Nov 2004
              • 166
              thanks for the input guys. anybody have a clue on the going rate through the dealership (or GMPD?)? no way I'm shelling out the cash for ARP everything.. this motor's not going to be making any sort of power where I'd be worried about ripping bolts apart...
