FPR Adapter for 3500s
  • CNCguy
    Bisong eater :P
    • 1017
    For those of you who have been waiting for these... here they are. The adapter rotates the stock FPR about 20 degrees to clear the 3500 UIM. I will most likely just send them bare metal and people can paint/coat them as they want.
    Stock FPR location
    FPR location with adapter
    Stock bracket compared to adapter brackets (front & rear)
    I plan to ship these to Ben this Wenesday and I am sure he will have them in the store shortly after he gets them.
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
  • onefastV6
    • Sep 2005
    • 880
    Marc - thanks, they look great I will be ordering one ASAP.
    2000 Grand Am GT
    2011 Chevy Impala
    • blackbombshell95
      Kaiō-ken X 10
      • Jun 2004
      • 1386
      CNC guy pulls off another sweet item. Can you make Ben some more of the plenum spacers . I need 2 sets
      02 GTP - 90* > Failboat
      www.blackbombshell95.com
      • CNCguy
        Bisong eater :P
        • 1017
        Planning on making some more in the near future. Ben was asking about making them 1/4" or 3/8" this time. I was going to check into some 1" thick material as well for those who may want to use them for nitrous or whatever.
        '79 MGB - LZ9 - T5
        • rickykline
          • Oct 2006
          • 345
          if you get the plenum spacers ill buy both those and this...
          • treeZ24
            i wanna go fast!
            • Mar 2004
            • 251
            hey neat! i just ground the neck off mine and made it fit but that is a way better solution imo
            great work
            got zap-straps?
            89 Z24
            13.886 @ 96.16 mph
            street trim - slicks
            • blackbombshell95
              Kaiō-ken X 10
              • Jun 2004
              • 1386
              I would be VERY interested in a thick 1 for nitrous. Well I should say Guaranteed to buy one that thick
              Would 1" be enough? or more like 1 1/2"???
              • MidnightriderZ24
                • Jan 2005
                • 699
                hey cnc, have u had a chance to see if the 3400 crank pulley will bolt up to the 3900's crank. i want to upgrade from 3400 turbo in my cavalier to 3900 turbo, and i want to use your external crank trigger..
                [SIGPIC]
                12.268@117... 11's to come!
                  • 13525
                  They are the same crank as far as I know. (3500 and 3900)
                  • CNCguy
                    Bisong eater :P
                    • 1017
                    Thats a good news - bad news situation. The pulley is interchangable and the reluctor wheel can be used but the CPS mount doesn't fit due to changes in bolt hole pattern. That is an issue that I plan to address when I get a chance.
                    I am not familiar with the Cavalier motor mount setup, will it clear the VVT actuator?
                    '79 MGB - LZ9 - T5
                      • 13525
                      We need to make a front mount piece like JBP sells for $$$. The cavalier doesn't have the side mount does it? I know the grand am and beretta do.
                      • sharkey
                        • Jun 2004
                        • 2061
                        early (82-94) j-body uses mounts like a pre 92 beretta.
                        front mount bracket is under the water pump pulley
                        rear mount is above the steady shaft
                        top tranny mount is behind my intake pipe under the wiring harness
                        there is a lower dogbone that goes to the subframe.
                        • MidnightriderZ24
                          • Jan 2005
                          • 699
                          do u have a picture of the VVT actuator? i must have missed it in your 3900 thread with all the pictures. got any dimensions of it? im not sure what it looks like.
                          [SIGPIC]
                          • CNCguy
                            Bisong eater :P
                            • 1017
                            I updated that thread to include some pics of the TC cover. Let me know if there is anything else you need to know.
                            http://60degreev6.com/showthread.php?t=34223
                            '79 MGB - LZ9 - T5
