Do you really need forged pistons?
  • rickykline
    • Oct 2006
    • 345
    358 on 9psi.... DAMN... what bolt ons.... i want specifics..lol
    • AaronGTR
      boost lover
      • Jan 2004
      • 708
      Not entirely true. The largest factor is going to be fuel ratio and timing while under boost. Thats will be the difference between a failure and a reliable motor. Sure metal flaws might be a factor. But it is not the most important one. Also depending on the temperature of the boosted air you might not have any problems at 15 PSI on one setup but might be overwhelmed at 9PSI on another setup
      Every piston and bearing surface is imediatly suspetable to failure under detonation. Every piston top is going to run excessivly hot under a lean condition even if there is no detonation.
      Heat makes power. But too much melts stuff
      Good points, but also just reinforces what I said. Remember that A/F ratio and timing and air density (temp) are just factors that affect cylinder pressure. Peak cylinder pressures and max HP are reached with optimum A/F ratio and timing. If your other factors aren't right though and you run too hot or too close to detonation then obviously you have to dial back timing and/or add fuel and/or try to cool the air charge and engine down in other ways. I kinda figured that was a given and we didn't need to go into that.
      '97 Grand Prix GT 3800 (sold)
      Gotta love boost!
      • fivepointhustla
        I prefer fast & reliable
        • May 2004
        • 181
        yeah midnight what the hell are you runnin. Those some awesome #s for 9psi
        Clean Feet Pet Clean Up
        Pet Waste Removal Omaha
        We offer dog waste removal and cat waste removal services.
        (402) 320-3824, We service the Omaha, Ne. metropolitan area.
        • MidnightriderZ24
          • Jan 2005
          • 699
          not too much http://www.v6z24.com/registry/midnightriderz24/4
          [SIGPIC]
          12.268@117... 11's to come!
          • blackbombshell95
            Kaiō-ken X 10
            • Jun 2004
            • 1386
            u still obd 2?
            02 GTP - 90* > Failboat
            www.blackbombshell95.com
            • rickykline
              • Oct 2006
              • 345
              #21
              if hes running a tgp chip im guessing hes still obd1.....
              • kwhauck
                Olds Sleeper
                • Aug 2006
                • 379
                #22
                i blew the #6 piston at 13-15psi.......
