Do you really need forged pistons?
  • fivepointhustla
    I prefer fast & reliable
    • May 2004
    • 181
    If you control detonation under boost or spray do you really need forged pistons?
    Could you just have the cast pistons crogentically frozen to increase strength?
    Clean Feet Pet Clean Up
    Pet Waste Removal Omaha
    We offer dog waste removal and cat waste removal services.
    (402) 320-3824, We service the Omaha, Ne. metropolitan area.
    • 13534
    To an extent, yes. Do I know the limits of hyper pistons in a 60V6? Nope. I don't know if cryo treating the pistons will increase that limit either. I know it works well for brake rotors though.
    What are you doing exactly?
      Well I have sucessfully run a 100 wet shot on Hyper pistons in a 3400 for quite some time... Dynoed at a 62whp gain.
      I have over 6-8 visits at the dragway, one day being 13 runs, others around d6-8 runs, all being sprayed, also the daily squirt once and a while on the road when there is juice in the bottle, and this was all on a stock un-tuned 95 ECM... I still have good compression and have never fouled a plug or seen any KR while running at the strip. 50k on the motor now and it still has good compression on all cylinders.
      To be specific these were Sealed power Hyper replacement pistons .030 over.
      • bjornmk1
        • Nov 2006
        • 266
        say..did you post on the pennock fiero forum about
        supercharging the engine with a m90 >interesting
        I can give you some tips,cause I am building one myself
        BTW I'm going with the forged pistons myself..just t be on the safe side.
        nothing's impossible-it's just a mindset
        • fivepointhustla
          • May 2004
          • 181
          yes I am goatnipples2002 on pennocks.
          I plan on running a 200shot nitrogen push system, until I get boosted. Since I have the juice now. I have been running a 100 shot for now.
          • bjornmk1
            • Nov 2006
            • 266
            well I am sc-ing mine with a ford m90.
            it is going where my airco pump used to be.
            doing that you'l need a relocator kit for the oilfilter.
            I shortened the snout of my sc-er to get the fitment I need.
            that way it wont suffer from the heat of the exhaust as much
            as the set up in the picture.
            I'm aiming at 240-250whp at aprox. 10-12psi.
            ported the alu heads an manifolds.
            350cc fuel injectors.
            audi s4 intercooler.
            what is yours going to be like
            B
            • fivepointhustla
              • May 2004
              • 181
              new thread
              http://60degreev6.com/showthread.php...160#post313160
              • MidnightriderZ24
                • Jan 2005
                • 699
                ive been running 12 psi on stock 3400 pistons for awhile and no sign of slap or any piston noise. really the only noise is the timing chain is a little loose. with my built 3500 i plan on runnin 20+ psi
                [SIGPIC]
                12.268@117... 11's to come!
                • farmerz24
                  • Feb 2004
                  • 361
                  yes i was running 10 psi for not a long time but did you see my piston cracked and the only thing holding it together was the cylinder wall? if i had kept goin it would have ended up like 89jyturbos and shattered.
                  forged are a must, especially if you want to be reliable.
                  • AaronGTR
                    boost lover
                    • Jan 2004
                    • 708
                    I think there definitely is a HP limit to what the pistons will take, even without detonation. You have to remember that HP is the result of increased cylinder pressure pushing down on the piston and eventually it will reach it's limit. That said, I also don't think there is a definitive HP number that can be used. Given the low tolerances and variences in metal quality and grain of stock pistons, the limit could be different for every engine. This is evident when some people run 12psi with no problems and other break a piston at 10psi. Obviously the one that broke at a lower level had some flaw from the factory.
                    I would say just for peace of mind and to lower the risk of damaging the rest of your engine with a blown piston, you should probably consider forged pistons for anything over 10psi or approaching 300whp.
                    '97 Grand Prix GT 3800 (sold)
                    Gotta love boost!
                    • rickykline
                      • Oct 2006
                      • 345
                      there have been several break 350whp with stock pistons.. i plan to upgrade to forged soon just so i can push the envelope
                      • geoffinbc
                        Iron Head Enthusiast
                        • 5831
                        Not entirely true. The largest factor is going to be fuel ratio and timing while under boost. Thats will be the difference between a failure and a reliable motor. Sure metal flaws might be a factor. But it is not the most important one. Also depending on the temperature of the boosted air you might not have any problems at 15 PSI on one setup but might be overwhelmed at 9PSI on another setup
                        Every piston and bearing surface is imediatly suspetable to failure under detonation. Every piston top is going to run excessivly hot under a lean condition even if there is no detonation.
                        Heat makes power. But too much melts stuff
                        • boostedrs
                          • Mar 2006
                          • 168
                          ive gone 18 psi + 35 shot of nitrous on my engine once,and ive continously run 18 psi on the motor without the nitrous,and its held together,on stock pistions.the main weak point is the top ringland,open up the ring gap a bit and u should be fine ,as long as ur tune is good .
                          i have had only one pistion falure between 3 diff motors,and it was due to going dead lean @ 20+ psi and detonating to hell (wastegate came unhooked).
                          • MidnightriderZ24
                            • Jan 2005
                            • 699
                            totally agree here. im running 12 now, dyno'd 358whp with 9 psi. i am intercooled and have a way better tune than kenton (89jy). i think i could easily run 15 psi but im not going to, traction is limited at 6 psi, try 12 psi!! a limited slip should fix that soon.
                            [SIGPIC]
                            • boostedrs
                              • Mar 2006
                              • 168
                              358@9#'s???? it took me 18 psi to hit 412.what size turbo u running?
                              edit nm i just noticed its a 3400 motor,mine was done on a iron headed 3.1,though im in the middle of a 3xxx swap now and switching to twin turbos
