est power
  • rx191
    • 123
    est power
    i'm looking for about 180hp from my berreta and lot better low end torque, this is what i have planed so far, i have to change the intake gaskest soon so i figure i'll start there.
    3400 lower
    3500 upper
    60 mm throttle body (not sure what from yet)
    2 1/2" down pipe with resonaotr deleted and uppgraded muffler
    cold air intake custom built
    it's rated at 155 stock so i figure about 180 with these mods sound be fesable i thought about doing the rockers too but an not sure if they are worth the gain or not, there a little expensive
    any hting eles let me know,
    • 9191
    What you listed won't gain you 25hp, thats for sure. If you're lucky, you'll get maybe 10 from what you've listed.
    • rx191
      • 123
      correct me if i'm wrong but didn't the 2000 up 3100 make 170 hp and 190 ft lbs, and the only diffenece was a little larger intake valve and the 3400 stlye intake, they didn't change the cam or anything major in the motor. thats 15hp right there, so i'm figureing just the 3400 intake is worth 10hp, that only puts me 15hp from my goal, the 3500 plemume has to be worth at least 5hp and the exausht 5hp, intake and throttle body 3hp, thats puts me pretty close to my goal, plus the lowend touqe that everyone says they get from these mods should make the car feel even faster.
      • sharkey
        • Jun 2004
        • 2061
        hard to say if you will get what your goal is just by those mods. the only sure way, drop in a 3400 with a cam in it and your good to go.
          • 13534
          Tuning is going to be the bigger factor IMO. The more you mod, the more you need tuning.
