Rear mount turbo
  • rx191
    • 123
    Rear mount turbo
    I got lucky today and had a firebird with a rear mount turbo come in the shop, i have to admit after driving one i can say the system works better than i could have ever dreamed. Heres the info 5.7 car with rear turbo stock exaust, the car produces boost as low as 1400 RPM it was around 2 pounds there and produced full boost at 2800 RPM of 9 pounds, there was no turbo lag at all, and the intake temps where very good less than 130 even at full boost, the only thing i didn't like about the system was the way it oiled, the return goes into the oil cap and just looks cheesy. a remote oil system would make these units ideal, i would love to put on my car this things is awsome
  • fivepointhustla
    I prefer fast & reliable
    • May 2004
    • 181
    Why..the reason for most of these systems is in cars that can't fit them. They use really small turbos and what if the electric oil pump goes out? To each their own, but in a car that has a 60V6 there should be room for a regular turbo set up.
    Clean Feet Pet Clean Up
    Pet Waste Removal Omaha
    We offer dog waste removal and cat waste removal services.
    (402) 320-3824, We service the Omaha, Ne. metropolitan area.
    • sharkey
      • Jun 2004
      • 2061
      yes the main reason is room, but they also have the advantage of being real easy to build the setup and install it. also if you have emmissions testing/inspection, you have the ability to just unbolt the entire setup and convert it back to "stock" within a couple hours. its a hotly debated topic on how good these systems realy are, but track times dont lie, and a z24 with a 3400 and remote mount running 12.5 isnt to shabby.
      of and the oiling: it uses engine oil pressure to feed the turbo. it uses an electric scavenging pump to feed oil back to the motor. if the pump dies, the car just starts smoking cause the oil is building up in the turbo.
      • fivepointhustla
        • May 2004
        • 181
        Yeah I'm in Nebraska and we don't have ANY emissions testing. So the visual would be a major plus.
        • gectek
          Banned
          • Aug 2006
          • 1472
          yah and sts (who makes the rear turbo) has the patent on that scavenge kit for the oil, and it doesnt have to inject back through the cap, that is just the easiest place where they can feed alot fo oil and it not get in the way of anything else. plus they dont need to be intercooled to produce good power without robbing timing and they can be used to higher boost apps on stock engines. also with the methanol injection kit you can go massive boost on mostly stock engines with no kr, detonation, or any high heat temps under the hood, plus it helps take more advantage of a coated exhaust, keeping the heat in the gas and making the velocity higher, plus you can use them with better fitting headers and many other mods without making too many adjustments, cuts, or rearranging
          and they even make a syst with dual tips where the waste gate goes through the one tip and the turbo is on the other
          • kwhauck
            Olds Sleeper
            • Aug 2006
            • 379
            sweet setups for sure...i got some pics on a gp here locally with the sts kit if you are interested.......
            • gectek
              Banned
              • Aug 2006
              • 1472
              yah i wanna see em, what year model?
              • kwhauck
                Olds Sleeper
                • Aug 2006
                • 379
                coming right up........i think it was an 01
                • kwhauck
                  Olds Sleeper
                  • Aug 2006
                  • 379
                  two more........they also have a gtp that is twin charged with the sts but i'm not sure what i did with those pics..........
                  • gectek
                    Banned
                    • Aug 2006
                    • 1472
                    are they not using the oil cap return line? if not where are they putting the oil back in at?
                    • gectek
                      Banned
                      • Aug 2006
                      • 1472
                      so the smaller pipe running up the drivers side is the intake piping? does it have an intercooler also?
                      • kwhauck
                        Olds Sleeper
                        • Aug 2006
                        • 379
                        not sure exactly obviously t'd in elsewhere
                        • gectek
                          Banned
                          • Aug 2006
                          • 1472
                          thats how mine is gonna b also, but with an I/C also
                          • kwhauck
                            Olds Sleeper
                            • Aug 2006
                            • 379
                            i rode for quite awhile in it and even without an intercooler the temps stayed down pretty far, about equal to what i used to pull on my roots/w2a setup.....
                            • sharkey
                              • Jun 2004
                              • 2061
                              sts claims that the pipe running from back to front works as about a 50% efficient intercooler, and claim less that 0.5psi pressure drop, were a normal intercooler is 1.5-2psi. an intercooler actualy isnt needed.
