Got my Cam today..
    Got my Cam today..
    Here is what's on the cam card.
    Lift @ Lobe
    .337 intake
    .343 Exhaust
    Lift @ valve
    .539 intake
    .549 exhaust
    Duration @ .050
    232.0 Intake
    238.1 Exhaust
    Advertised Duration (.006)
    287.7 Intake
    293.2 Exhaust
    LSA
    110
    Overlap
    70.45°
    Advance
    4°
    Intake Centerline
    106
    Should work out pretty good.. it's gonna idle like crap though... lmao
  • sprucegagt
    Old School KI
    • May 2005
    • 703
    Have fun trying to get that thing to idle. I like the lift numbers but the duration is too much for my taste. Also, I thought you said in another thread that you changed your specs to get 62.5° of overlap?
    Your local OBDII moderator
    2000 Grand Am GT w/ WOT parts
      Yah but apparently my numbers didn't match Delta's avaliable profiles so they made some adjustments..
      I'm not too worried, i knew what i was getting into with this cam and i'm prepared to deal with the idle issues. I've ran bigger in computer controlled V8's.. just gotta bump the idle up a few hundred RPM.. or trick the MAP like i'm planning on doing. :P
      • RedBird
        Aka Mr. 5th Motor
        • Sep 2006
        • 426
        isn't that more overlap than you started out with, before you got it down to the 62.5 #? Jeez........
        Have fun with that one, lol.....
        Cammed 3400 --> 224whp 210wtq
        Cammed 3500 --> ???
        1 of 5 3500 J-Bodies
          Yah, vacuum pump time... gonna have to find one at the JY or buy a new one, lol
            • 13531
            So it wants you to advance the cam 4 degrees? My similar grind is a 109.5 ICL but calls for 1.5 advance to make it 108. I don't think your specs are possible without advancing the the cam 4 degrees.
              here is a compairson of the base circles of the new cam and a stock 3400 cam...
              Ben, I'm assuming that's true. That was why i was asking about degreeing in the cam in the other thread.
              I'll post up a scan of the card in a little while...
              *edit, here is the card...
                • 13531
                I put your cam into my program. PM me with your bore, compression, heads and intakes and exhaust setup, flow numbers if you have them.
                • gectek
                  Banned
                  • Aug 2006
                  • 1472
                  is this a core that delta had, or a used cam u sent in, and also why is there so much pitting on the lobes?
                    that's oil
                    it was a core that i bought from the 60v6 store
                    Ben, i'll do that in a few...
                    • gectek
                      Banned
                      • Aug 2006
                      • 1472
                      ah that 'splains alot...lol
                      so how is the finish on the cam since i cant tell from the pics. also have u thought about cryo treating it or is it going in the engine right away...also sappy, how r u comming along on the double roller chain setup?
                        no cryo treating.. lol it's going in the engine in the morning.
                        finish is excellent, looks better than it did before the grind.
                        for the double roller chain, i wonder if we could use the LSx ones but have the manufacturer make us a longer chain...
                        the double roller setup for the gen2's may work but who knows... JBP sells them for the 3.1/3100/3400 though. (i'm sure you could get it cheaper anywhere else)
                        • gectek
                          Banned
                          • Aug 2006
                          • 1472
                          well all i would need is the locations for the "machining" and id take one from cloyes, but those are a 3 bolt and i thought the 3400 cam was a single bolt...
                          • 93ztwo4
                            • Nov 2006
                            • 75
                            http://www.jbodyperformance.com/new/...catName=JP0189
                            yeah and i am sure it wouldnt take 3 months to get it
                              • 13531
                              I have a double roller here. That isn't fitting a gen 3 or 4. You have to machine the inside for the bolt hole to fit on the cam, and machine the dowel pin hole to get that to fit. After you do that, you will notice that the timing chian cover has to be machined so much that you will go through the surface. I just got through with all that. Good luck. Ill sell mine that is modified other than the cover for 120. Its adjustable +- 4 degrees at the crank as well.
